CA12239_MINNIE-M
CA12239_MINNIE-M
    LEDIL(芬兰)
    REFLECTOR 35MM RND 15.8MM
CA12239_MINNIE-M 数据手册
PRODUCT DATASHEET CA12239_MINNIE-M MINNIE-M ~25° medium beam optimized for CREE MT-G. Assembly with holder and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 35.0 mm 15.8 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour MINNIE-M Reflector PC metal MINNIE-HLD-2 Holder PC black SPUTNIK-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA12239_MINNIE-M » Box size: Qty in box Reflector 840 MOQ MPQ 120 60 Last update: 12/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 6.1 1/4 PRODUCT DATASHEET CA12239_MINNIE-M See also our general installation guide: www.ledil.com/installation_guide Last update: 12/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/4 PRODUCT DATASHEET CA12239_MINNIE-M PHOTOMETRIC DATA (MEASURED): LED MT-G FWHM / FWTM 26.0° / 84.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED MT-G2 FWHM / FWTM 22.0° / 71.0° Efficiency 88 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 12/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/4 PRODUCT DATASHEET CA12239_MINNIE-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 12/07/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/4
CA12239_MINNIE-M
1. 物料型号:MINNIE-M,一个直径35.0毫米、高度15.8毫米的反射器,配有固定带和安装胶带,优化了CREE MT-G的光束角度。
2. 器件简介:MINNIE-M是一个反射器,配有PC材料的固定器和丙烯酸泡沫胶带,颜色为黑色。
3. 引脚分配:文档中没有提供引脚分配信息,因为它是一个LED光学组件,不是电子元件。
4. 参数特性: - 尺寸:直径35.0毫米,高度15.0毫米。 - 固定胶带:符合ROHS标准。 - 光度数据:使用CREE LED MT-G和MT-G2,具有不同的视场角(FWHM / FWTM)和效率。
5. 功能详解:文档提供了关于光束角度、材料和产品数据用户协议的详细信息。
6. 应用信息:文档提到了产品的一般安装指南,可在www.ledil.com/installation_guide找到。
7. 封装信息:提供了订购信息,包括每箱数量、最小订购量(MOQ)、最大包装量(MPQ)和箱重。
8. 公司信息:LEDiL Oy的联系信息,包括芬兰、美国和中国的地址。
CA12239_MINNIE-M 价格&库存
很抱歉,暂时无法提供与“CA12239_MINNIE-M”相匹配的价格&库存,您可以联系我们找货
