F13663_ANGELA-M-B
F13663_ANGELA-M-B
    LEDIL(芬兰)
    REFLECTOR ROUND 0 POS 119.5MM D
F13663_ANGELA-M-B 数据手册
PRODUCT DATASHEET F13663_ANGELA-M-B ANGELA-M-B ~30° medium connectors beam compatible with BJB TECHNICAL SPECIFICATIONS: Dimensions Ø 119.5 mm Height 74.5 mm Fastening socket ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour ANGELA-M-B Reflector PC metal Finish Coating HMDS ORDERING INFORMATION: Component F13663_ANGELA-M-B » Box size: 398 x 298 x 265 mm Qty in box 180 MOQ MPQ 90 45 Box weight (kg) 9.1 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/16 PRODUCT DATASHEET F13663_ANGELA-M-B See also our general installation guide: www.ledil.com/installation_guide Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED BXRA ES Rectangle FWHM / FWTM 16.0° / 58.0° Efficiency 82 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2040 LED V15 Gen6 FWHM / FWTM 19.0° / 69.0° Efficiency 77 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2224 LED V15 Gen6 FWHM / FWTM 18.0° / 67.0° Efficiency 80 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2224 LED V18 Gen6 FWHM / FWTM 21.0° / 69.0° Efficiency 77 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2274 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED V18 Gen7 FWHM / FWTM 19.0° / 68.0° Efficiency 81 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2350 LED V22 Gen6 FWHM / FWTM 22.0° / 69.0° Efficiency 78 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 LED V22 Gen6 FWHM / FWTM 23.0° / 70.0° Efficiency 74 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8102-G2 LED CLL03x/CLU03x FWHM / FWTM 16.0° / 57.0° Efficiency 83 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 18.0° / 67.0° Efficiency 77 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8101-G2 LED CLL03x/CLU03x FWHM / FWTM 16.0° / 61.0° Efficiency 83 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8101-G2 LED CLL04x/CLU04x FWHM / FWTM 22.0° / 70.0° Efficiency 76 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8102-G2 LED CLL04x/CLU04x FWHM / FWTM 21.0° / 69.0° Efficiency 81 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 21.0° / 62.0° Efficiency 81 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED CLU720/721 FWHM / FWTM 14.0° / 50.0° Efficiency 82 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED CLU720/721 FWHM / FWTM 14.0° / 53.0° Efficiency 83 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8101-G2 LED CXA/B 25xx FWHM / FWTM 18.0° / 67.0° Efficiency 82 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8401-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED CXA/B 25xx FWHM / FWTM 21.0° / 69.0° Efficiency 76 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2141 LED CXA/B 25xx FWHM / FWTM 20.0° / 68.0° Efficiency 79 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2141 LED CXA/B 30xx FWHM / FWTM 21.0° / 68.0° Efficiency 80 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8404-G2 LED LUXEON CoB 1204/1205 FWHM / FWTM 16.0° / 56.0° Efficiency 82 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8301-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 19.0° / 69.0° Efficiency 77 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8301-G2 LED LUXEON CoB 1208 FWHM / FWTM 17.0° / 64.0° Efficiency 83 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8301-G2 LED LUXEON CoB 1211 FWHM / FWTM 19.0° / 67.0° Efficiency 80 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED LUXEON CoB 1211 FWHM / FWTM 19.0° / 67.0° Efficiency 81 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED LUXEON CoB 1216/1812 FWHM / FWTM 22.0° / 69.0° Efficiency 79 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED LUXEON CoB 1216/1812 FWHM / FWTM 24.0° / 70.0° Efficiency 75 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2030 LED LUXEON K12 FWHM / FWTM 17.0° / 65.0° Efficiency 87 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2070 LED LUXEON K16 FWHM / FWTM 17.0° / 67.0° Efficiency 87 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2070 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED CxM-14 (19x19) FWHM / FWTM 16.0° / 56.0° Efficiency 82 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED CxM-22 (28x28) FWHM / FWTM 22.0° / 69.0° Efficiency 81 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED Soleriq S13 FWHM / FWTM 15.0° / 55.0° Efficiency 83 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8502-G2 LED Soleriq S13 19x19 FWHM / FWTM 16.0° / 56.0° Efficiency 80 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED Soleriq S19 FWHM / FWTM 17.0° / 65.0° Efficiency 83 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8503-G2 LED Soleriq S19 FWHM / FWTM 18.0° / 65.0° Efficiency 83 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2170 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 18.0° / 68.0° Efficiency 78 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2021 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 18.0° / 68.0° Efficiency 78 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS A.A.G. STUCCHI: 8101-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 17.0° / 66.0° Efficiency 81 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 17.0° / 66.0° Efficiency 81 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8101-G2 LED ZC12/18 FWHM / FWTM 16.0° / 57.0° Efficiency 82 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8101-G2 LED ZC25/40/60 FWHM / FWTM 23.0° / 68.0° Efficiency 81 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED ZC25/40/60 FWHM / FWTM 21.0° / 68.0° Efficiency 81 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 LED ZC25/40/60 FWHM / FWTM 24.0° / 69.0° Efficiency 77 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: F13671_ANGE-RZ-LENS BJB: 47.319.2030 LED Mega Zenigata (GW6DME) FWHM / FWTM 17.0° / 61.0° Efficiency 84 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2011 LED Mega Zenigata (GW6DME) FWHM / FWTM 17.0° / 63.0° Efficiency 83 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8301-G2 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (MEASURED): LED SLE G7 LES17 H FWHM / FWTM 17.0° / 66.0° Efficiency 80 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SLE G7 LES21 H FWHM / FWTM 20.0° / 68.0° Efficiency 80 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XOB 14.5 mm FWHM / FWTM 17.0° / 66.0° Efficiency 82 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED XTM - 19mm LES FWHM / FWTM 19.0° / 68.0° Efficiency 81 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C15743_XTM-ADAPTER-50-B Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/16 PRODUCT DATASHEET F13663_ANGELA-M-B PHOTOMETRIC DATA (SIMULATED): LED CLU730/731 FWHM / FWTM 16.0° / 26.0° Efficiency 91 % LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 LED Soleriq S15 FWHM / FWTM 18.0° / 30.0° Efficiency 90 % Peak intensity 6 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2021 LED LC040D / LC060D / LC080D FWHM / FWTM 23.0° / 45.0° Efficiency 87 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: BJB: 47.319.2030 Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/16 PRODUCT DATASHEET F13663_ANGELA-M-B GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 22/08/2019 Subject to change without prior notice Published: 30/04/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/16
F13663_ANGELA-M-B 价格&库存
很抱歉,暂时无法提供与“F13663_ANGELA-M-B”相匹配的价格&库存,您可以联系我们找货
F13663_ANGELA-M-B
  • 1+64.502661+8.08080
  • 4+63.616634+7.96980
  • 15+62.8192115+7.86990
  • 30+62.3761930+7.81440
  • 75+61.4015775+7.69230
F13663_ANGELA-M-B
  • 45+49.3516245+6.18270
  • 135+48.99721135+6.13830
  • 180+48.90861180+6.12720
  • 450+48.55420450+6.08280
  • 675+48.28839675+6.04950
F13663_ANGELA-M-B
    • 1+61.48330
    • 10+58.41122
    • 45+56.07852
    库存:89
    F13663_ANGELA-M-B
    • 45+43.2380445+5.41680
    • 90+42.7950390+5.36130
    • 135+42.52922135+5.32800
    • 180+42.26342180+5.29470
    • 225+41.73180225+5.22810
