CN12166_LENA-M-DL
CN12166_LENA-M-DL
    LEDIL(芬兰)
    REFLECTOR 86.1MM RND CITIZEN MED
CN12166_LENA-M-DL 数据手册
PRODUCT DATASHEET Lena series last update 9/11/2012 Ordering number CN12166_LENA-M-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CL-L340 Metal 111 mm 86.1 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 24 degrees 78 % 3.800 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. January 4th 2013 12:53 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 9/11/2012 GENERAL INFORMATION - Product series especially designed & optimized for CL-L340 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). January 4th 2013 12:53 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of CA12166_Lena-M-Diffuser-Lens-CL340 100% 75% 50% 25% 0% 50 40 30 20 10 0 -10 -20 -30 -40 -50
CN12166_LENA-M-DL 价格&库存
很抱歉,暂时无法提供与“CN12166_LENA-M-DL”相匹配的价格&库存,您可以联系我们找货
