CN12713_LENA-M
CN12713_LENA-M
    LEDIL(芬兰)
    REFLECTOR 111MM RND CITIZEN MED
CN12713_LENA-M 数据手册
PRODUCT DATASHEET Lena series last update 5/7/2012 Ordering number CN12712_LENA-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 12 degrees 88 % Available FWHM Efficiency cd/lm Gerber File 12 degrees 83 % Available FWHM Efficiency cd/lm Gerber File 19 degrees 86 % Available FWHM Efficiency cd/lm Gerber File 20 degrees 81 % Available Ordering number CN12718_LENA-S-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready Ordering number CN12713_LENA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready Ordering number CN12719_LENA-M-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready December 25th 2012 13:28 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 5/7/2012 Ordering number CN12714_LENA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 43 degrees 83 % Available FWHM Efficiency cd/lm Gerber File 44 degrees 78 % Available Ordering number CN12720_LENA-W-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL030 Metal 111 mm 85.4 mm Round PC PC Screw Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. December 25th 2012 13:28 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 5/7/2012 GENERAL INFORMATION - Product series especially designed & optimized for CLL030 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). December 25th 2012 13:28 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of CN12712_LENA-S (CLL030-1208) 100% 75% 50% 25% 0% 35 30 25 20 15 10 5 0 -5 -10 -15 -20 -25 -30 -35 Relative intensity of CN12718_LENA-S-DL (CLL030-1208) 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 Relative intensity of CN12713_LENA-M (CLL030-1208) 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 Relative intensity of CN12719_LENA-M-DL (CLL030-1208) 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 Relative intensity of CN12714_LENA-W (CLL030-1208) 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 Relative intensity of CN12720_LENA-W-DL (CLL030-1208) 100% 75% 50% 25% 0% 40 30 20 10 0 -10 -20 -30 -40 A B C D 4 4 11 Top view Isometric view . 6 1 4 7. 5 4 . 94 3 3 8 6.6 5 1 Front view Scale: 1:1 Holder base - PC - Color white 1 DRAWN BY DATE CHECKED BY DATE DESIGNED BY DATE Led Sal FIN Fin DRAWING TITLE as 10.04.2012 15.03.2012 D 2 Front view This drawing is our property. It can't be reproduced or communicated without our written agreement. pl 86.7 Reflector - PC - Metal coating and clear lacquer 85.4 subLens - PMMA 82.3 2 Bottom view (with sublens) 43 Material: 3.2 Datasheet Lena-CLL030 series Assy SIZE DRAWING NUMBER REV 1 A4 SCALE 1:2 WEIGHT(g) SHEET A 1/1 1
CN12713_LENA-M 价格&库存
很抱歉,暂时无法提供与“CN12713_LENA-M”相匹配的价格&库存,您可以联系我们找货
