CN12722_LENA-M-DL
CN12722_LENA-M-DL
    LEDIL(芬兰)
    REFLECTOR 111MM RND CITIZEN
CN12722_LENA-M-DL 数据手册
PRODUCT DATASHEET Lena series last update 5/7/2012 Ordering number CN13164_LENA-WAS Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Assembly CLL040 Metal 111 mm Round PC Ready FWHM Efficiency cd/lm Gerber File 0Asymmetric degrees 82 % 0.950 Available FWHM Efficiency cd/lm Gerber File Asymmetric degrees 78 % 0.810 Available FWHM Efficiency cd/lm Gerber File 15 degrees 84 % 5.250 Available FWHM Efficiency cd/lm Gerber File 16 degrees 79 % 3.820 Available Ordering number CN13174_LENA-WAS-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Assembly CLL040 Metal 111 mm Round PC Ready Ordering number CN12715_LENA-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 86.3 mm Round PC PC Screw Ready Ordering number CN12721_LENA-S-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 87.6 mm Round PC PC Screw Ready January 17th 2013 9:42 Copyright Ledil Oy - Subject to change without prior notice - Page 1/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 5/7/2012 Ordering number CN12716_LENA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 86.3 mm Round PC PC Screw Ready FWHM Efficiency cd/lm Gerber File 23 degrees 82 % 3.380 Available FWHM Efficiency cd/lm Gerber File 24 degrees 77 % 2.670 Available FWHM Efficiency cd/lm Gerber File 46 degrees 81 % 1.240 Available FWHM Efficiency cd/lm Gerber File 46 degrees 76 % 1.090 Available Ordering number CN12722_LENA-M-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 87.6 mm Round PC PC Screw Ready Ordering number CN12717_LENA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 86.3 mm Round PC PC Screw Ready Ordering number CN12723_LENA-W-DL Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Lena Reflector CLL040 Metal 111 mm 87.6 mm Round PC PC Screw Ready January 17th 2013 9:42 Copyright Ledil Oy - Subject to change without prior notice - Page 2/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 5/7/2012 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. January 17th 2013 9:42 Copyright Ledil Oy - Subject to change without prior notice - Page 3/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Lena series last update 5/7/2012 GENERAL INFORMATION - Product series especially designed & optimized for CLL040 series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PC with high UV and temperature resistance (120 degrees of Celcius / 248 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used materials from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PC%20Makrolon%202400_2407_2456_2458-UL .pdf - Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with protective lacquer (110 degrees of Celcius / 230 degrees of Fahrenheit). - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). January 17th 2013 9:42 Copyright Ledil Oy - Subject to change without prior notice - Page 4/4 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 Relative intensity of CN12715_LENA-S_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 Relative intensity of CN12721_LENA-S-DL_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 Relative intensity of CN12716_LENA-M_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 Relative intensity of CN12722_LENA-M-DL_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 Relative intensity of CN12717_LENA-W_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 Relative intensity of CN12723_LENA-W-DL_(CLL040) 100% 75% 50% 25% 0% 70 60 50 40 30 20 10 0 -10 -20 -30 -40 -50 -60 -70 A B C D 38.9 2.1 4 4 Isometric view Front view . 58 6 3 3 3.2 43 111 2 2 Materials Top view Reflector: PC Base part: PC Sublens: PC Note: Using additional sublens add 2,1mm to total height. This drawing is our property. It can't be reproduced or communicated without our written agreement. 1 DRAWN BY as DATE Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE 26.9.2012 CHECKED BY DATE SIZE - DESIGNED BY DATE A4 vs - - D SCALE PART NUMBER Mechanical drawing LENA-WAS 1 REV 001 1:4 WEIGHT - mg SHEET A 1/1
CN12722_LENA-M-DL 价格&库存
很抱歉,暂时无法提供与“CN12722_LENA-M-DL”相匹配的价格&库存,您可以联系我们找货
