8
D
7
5
6
4
2
3
NOTES:
1.
MOUNTING: Mounts in a .250 .002 [ 6.35mm .05] panel hole on .375 [9.5mm] centers.
Panel thickness .031 [.8 mm] to .250 [6.35mm]. Panel hole should be deburred, but not
chamfered.
ASSEMBLY: Insert lens through panel hole, (for thin panels less than .188 [4.75mm] thick, slide
2.
SPC 125 spacer on back of lens), and insert LED into lens.
MATERIAL: Polycarbonate, UL 94-V2
3.
GLO Series- Polycarbonate & Acrylic blend
4.
U.S. & Foreign Pat. Issued & Pend.
ECN#
REV.
1
2
3
001
1
REVISIONS
DESCRIPTION
VARIOUS
ADD GLO SERIES
REMOVE RNG 268, ADD UL RATING TO MATERIAL
REVISED PER ECR111009AZ01
DATE
5-91
1-6-09
9-16-09
4-23-10
INITIALS
JS
JG
AZ
SMU
D
SPACER
(ORDER SEPARATELY)
C
C
.430
10.92mm
SPC 125
.250
6.35mm
.280
7.11mm
B
B
ORDERING CODE :
.270
6.86mm
.070
1.79mm
CLB 300 XXX
MODEL
LENS COLOR
RTP
RED TRANSPARENT
ATP AMBER TRANSPARENT
GTP GREEN TRANSPARENT
BTP
BLUE TRANSPARENT
YTP YELLOW TRANSPARENT
CTP CLEAR TRANSPARENT
GLO WHITE TRANSLUCENT
A
8
7
DISPLAY
PANEL
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN INCHES:
ANGLES
1'
FINISH
MATERIAL
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
LED
LENS
VISUAL COMMUNICATIONS COMPANY, INC.
POLYCARBONATE,
UL 94-V2
DECIMALS
.X
.020
.010
.XX
.XXX .005
SPC 125 SPACER
DATE
APPROVAL
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
ASSEMBLY
6
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
5
4
3
DRAWN:
CHECKED:
5MM ROUND LOW
PROFILE FRESNEL LENS
SMU 4-23-10
DZ 4-23-10
SIZE
SCALE: 1:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B CLB 300 XXX
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CLB_300_CTP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.751841+0.90278
- 10+5.3752410+0.62600
- 100+3.90821100+0.45515
- 500+3.25364500+0.37892
- 1000+3.038721000+0.35389
- 2000+2.856172000+0.33263
- 5000+2.656565000+0.30938
- 10000+2.5320910000+0.29489
- 25000+2.3963525000+0.27908
- 国内价格
- 1+3.84480
- 200+1.53360
- 500+1.47960
- 1000+1.45800
- 国内价格
- 20+3.72870
- 260+3.64641
- 500+3.53746
- 国内价格
- 1000+2.26481
- 2000+2.19642
- 4000+2.15238
