CLF_280_CTP
CLF_280_CTP
    VCC
    CLF_280_CTP
CLF_280_CTP 数据手册
8 D 7 5 6 4 NOTES: MOUNTING: Mounts in a .250 .002 [ 6.35mm .05] panel hole on .375 [9.5mm] centers. 1. Panel thickness .063 [1.6mm] to .125 [3.17mm]. Panel hole should be deburred, but not chamfered. 2. ASSEMBLY: Insert lens through panel hole, and insert LED into lens. 3. MATERIAL: Polycarbonate, UL 94-V2 GLO Series- Polycarbonate & Acrylic blend 4. U.S. & Foreign Pat. Issued & Pend. 2 3 ECN# 1 REVISIONS DESCRIPTION REV. DATE INITIALS 1 ADD GLO SERIES 1-6-09 JG 001 REVISED PER ECR111009AZ01 4-23-10 SMU D C C .430 10.92mm .280 7.11mm .250 6.35mm B B .215 5.47mm ORDERING CODE : .125 3.18mm CLF 280 XXX MODEL LENS COLOR RTP RED TRANSPARENT ATP AMBER TRANSPARENT GTP GREEN TRANSPARENT BTP BLUE TRANSPARENT YTP YELLOW TRANSPARENT CTP CLEAR TRANSPARENT GLO WHITE TRANSLUCENT A 8 7 DISPLAY PANEL UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES: ANGLES 1' FINISH MATERIAL BREAK ALL CORNERS AND SHARP EDGES .030 MAX VISUAL COMMUNICATIONS COMPANY, INC. POLYCARBONATE, UL 94-V2 DECIMALS .X .020 .010 .XX .XXX .005 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com FINISH TITLE: SEE NOTES LENS LED DATE APPROVAL THIRD ANGLE PROJECTION ASSEMBLY PROPRIETARY AND CONFIDENTIAL THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 6 5 4 3 DRAWN: CHECKED: 5MM ROUND STANDARD HEIGHT FRESNEL LENS SMU 4-23-10 DZ 4-23-10 SIZE SCALE: 1:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B CLF 280 XXX 001 SHEET 1 OF 1 1 A
CLF_280_CTP 价格&库存
很抱歉,暂时无法提供与“CLF_280_CTP”相匹配的价格&库存,您可以联系我们找货
CLF_280_CTP
  • 1+8.032921+1.03964
  • 10+5.6016810+0.72499
  • 100+4.10085100+0.53075
  • 500+3.43093500+0.44404
  • 1000+3.211261000+0.41561
  • 2000+3.024722000+0.39147
  • 5000+2.820855000+0.36508
  • 10000+2.6937410000+0.34863
  • 25000+2.5552025000+0.33070
库存:29265
CLF_280_CTP
    • 1+4.10400
    • 200+1.64160
    • 500+1.58760
    • 1000+1.55520
