10417
10417
    CARCLO
10417 数据手册
1 A B 2 3 4 5 6 7 CUSTOMER DRAWING SHEET 2 ONLY 8 9 10 11 12 REV. DATE 1 17/11/08 1A 05/12/11 13 14 15 D.C.N. NUMBER 16 17 18 19 DESCRIPTION 12-11-1322 20 CHECKED BY APPROVED BY DATE DATE FIRST ISSUE NAME dd/mm/yy NAME dd/mm/yy DRAWING UPDATED WITH NEW DRW. STANDARDS AND NEW CARCLO OPTICS FORMAT FOR FULL DETAILS SEE D.C.N PW 16/07/12 MH 16/07/12 C PCB TOP VIEW D TOP VIEW E F 9.90± 0.10 -DRAFT == 8.00± 0.05 == BOTTOM VIEW 2.45± 0.10 4 OFF +DRAFT 9.90± 0.10 -DRAFT == 0.30± 0.10 TYP G 1.4 4 OFF 8.00± 0.05 == C OPTICAL SURFACES 8.00± 0.05 == GLUE PADS C 8.00± 0.05 == LED LENS POSITION 1.00± 0.10 2 OFF H 1.10 x 0.7 DEEP LOCATION HOLE 2 OFF DIAGONAL 1.44±0.10 0.40± 0.10 2 OFF I 6.00±0.10 6.40 REF L M PCB SAMPLE LAYOUT BASED ON A STANDARD THICKNESS 1.5mm + COATING SECTION C-C NOTES: SCALE 1 - MATERIAL: POLYCARBONATE N SCALE 4:1 2 - FINISH: COMMERCIAL POLISH FOR ALL NON OPTICAL SURFACES. OPTICAL SURFACES ARE OPTICALLY POLISHED SCALE 4:1 1:1 Sheet 2 of 2 3 - OVERALL PART THICKNESS = SEE 3D FILE O Title 4 - COLOUR CLEAR 5 - GENERAL DRAFT 2° P 6 - SIMPLIFIED GEOMETRY SHOWN. NOT SUITABLE FOR OPTICAL RAYTRACE 10mm SQUARE FRONT LENS OPTIC FP Drawn by THIRD ANGLE PROJECTION GENERAL TOLERANCES UNLESS OTHERWISE STATED LINEAR ANGULAR 0 ± 0.0 ± 0.00 ± 0.25 0.1 0.05 0 ± 0.0 ± 0.00 ± 1° 0.5 ° 0.1 ° Customer CARCLO CARCLO Optics CONFIDENTIAL: UNAUTHORISED COPYING, DISCUSSION & DISTRIBUTION PROHIBITED Scale DIMENSIONS IN mm CAD File 60553 Part N° 10417 Format Size Drw N° 60553 AS SPEC. A3
10417 价格&库存
很抱歉,暂时无法提供与“10417”相匹配的价格&库存,您可以联系我们找货
      库存:1774
      10417
