CA11663_HEIDI-RS
CA11663_HEIDI-RS
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM RND 11.7MM
CA11663_HEIDI-RS 数据手册
PRODUCT DATASHEET CA11663_HEIDI-RS HEIDI-RS ~8° spot beam TECHNICAL SPECIFICATIONS: Dimensions Ø 21.6 mm Height 11.7 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour HEIDI-RS Single lens PMMA clear HEIDI-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11663_HEIDI-RS » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 3264 204 204 Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.4 1/15 PRODUCT DATASHEET CA11663_HEIDI-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 8.0° Efficiency 91 % Peak intensity 19.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-H FWHM / FWTM 10.0° / 19.0° Efficiency 90 % Peak intensity 18.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 8.0° / 18.0° Efficiency 93 % Peak intensity 26.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 8.0° / 14.0° Efficiency 90 % Peak intensity 38 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED XP-G FWHM / FWTM 9.0° / 20.0° Efficiency 93 % Peak intensity 16.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 11.0° / 20.0° Efficiency 91 % Peak intensity 19.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 6.0° / 12.0° Efficiency 94 % Peak intensity 42.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 5.0° / 11.0° Efficiency 94 % Peak intensity 55.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED XT-E FWHM / FWTM 10.0° / 21.0° Efficiency 97 % Peak intensity 17.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 7.0° / 14.0° Efficiency 92 % Peak intensity 35.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 11.0° / 20.0° Efficiency 92 % Peak intensity 16.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 10.0° / 20.0° Efficiency 90 % Peak intensity 19.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED NCSxx19A FWHM / FWTM 8.0° / 18.0° Efficiency 89 % Peak intensity 19 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM / FWTM 9.0° / 18.0° Efficiency 90 % Peak intensity 25.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 10.0° / 23.0° Efficiency 89 % Peak intensity 13.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 12.0° / 26.0° Efficiency 92 % Peak intensity 13.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED NVSxx19B/NVSxx19C FWHM / FWTM 12.0° / 21.0° Efficiency 96 % Peak intensity 14.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 10.0° / 20.0° Efficiency 89 % Peak intensity 20.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 7.0° / 16.0° Efficiency 93 % Peak intensity 24.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH181A FWHM / FWTM 8.0° / 24.0° Efficiency 94 % Peak intensity 14.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (MEASURED): LED LH181B FWHM / FWTM 9.0° / 24.0° Efficiency 94 % Peak intensity 15 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 11.0° / 19.0° Efficiency 89 % Peak intensity 20.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 7.0° / 16.0° Efficiency 93 % Peak intensity 32.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 11.0° / 19.0° Efficiency 94 % Peak intensity 17.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED XHP35.2 HD FWHM / FWTM 20.0° / 34.0° Efficiency 91 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HI FWHM / FWTM 16.0° / 29.0° Efficiency 94 % Peak intensity 8.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 48.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X FWHM / FWTM 14.0° / 26.0° Efficiency 94 % Peak intensity 11.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED LUXEON Rubix FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 47.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 48.4 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 46.4 cd/lm LEDs/each optic 1 Light colour Green Required components: LED LUXEON Rubix FWHM / FWTM 6.0° / 14.0° Efficiency 96 % Peak intensity 45.6 cd/lm LEDs/each optic 1 Light colour Blue Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 8.0° / 16.0° Efficiency 96 % Peak intensity 30 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 8.0° / 17.0° Efficiency 91 % Peak intensity 28.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z FWHM / FWTM 6.0° / 14.0° Efficiency 95 % Peak intensity 51.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 7.7° / 17.0° Efficiency 94 % Peak intensity 33.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED SST-20 FWHM / FWTM 10.0° / 19.0° Efficiency 94 % Peak intensity 22.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 14.0° / 28.0° Efficiency 92 % Peak intensity 9.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 8.0° / 20.0° Efficiency 93 % Peak intensity 20.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 7.1° / 16.0° Efficiency 96 % Peak intensity 34.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED OSLON PURE 1010 FWHM / FWTM 8.0° / 16.0° Efficiency 93 % Peak intensity 29.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 12.0° Efficiency % Peak intensity 11.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4170S FWHM / FWTM 6.0° / 14.0° Efficiency 88 % LEDs/each optic 1 Light colour IR Required components: LED LH351B FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 14.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/15 PRODUCT DATASHEET CA11663_HEIDI-RS PHOTOMETRIC DATA (SIMULATED): LED LH351C FWHM / FWTM 12.0° / 24.0° Efficiency 95 % Peak intensity 13.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/15 PRODUCT DATASHEET CA11663_HEIDI-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 29/07/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/15
CA11663_HEIDI-RS 价格&库存
很抱歉,暂时无法提供与“CA11663_HEIDI-RS”相匹配的价格&库存,您可以联系我们找货
CA11663_HEIDI-RS
  • 204+9.48048204+1.18770
  • 408+9.39187408+1.17660
  • 612+9.34778612+1.17108
  • 816+9.34757816+1.17105
  • 1020+9.214671020+1.15440
库存:5916
CA11663_HEIDI-RS
    • 204+11.07532204+1.38750
    • 612+10.89812612+1.36530
    • 816+10.84695816+1.35889
    • 2040+10.809512040+1.35420
    • 3060+10.632313060+1.33200
    CA11663_HEIDI-RS
    • 4+23.66337
    • 52+23.14267
    • 104+22.64802
    库存:304
