SMC_170_GTP
SMC_170_GTP
    VCC
    SMC_170_GTP
SMC_170_GTP 数据手册
8 D 7 5 6 4 NOTES: MOUNTING: Mounts in a .171 .002 [ 4.34mm .05] panel hole on .250 [6.35mm] centers. 1. Panel thickness .031 [.8mm] to .094 [2.39mm]. Panel hole should be deburred, but not chamfered. 2. ASSEMBLY:Insert lens through panel hole, slide RNG 132 retainer on back of lens. PCB mounted LEDs slide into lens when the panel cover is closed or the PCB card is inserted into the case. 3. MATERIAL: Polycarbonate, UL 94-V2 4. U.S. & Foreign Pat. Issued & Pend. 2 3 ECN# 1 REV. REVISIONS DESCRIPTION 001 REVISED PER ECR111009AZ01 DATE INITIALS 4-23-10 SMU D RETAINER (ORDER SEPARATELY) C C .270 6.85mm RNG 132 .154 3.91mm .193 4.9mm .170 4.32mm B B .060 1.52mm ORDERING CODE : SMC 170 XXX MODEL RTP ATP GTP BTP YTP CTP A LENS COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT DISPAY PANEL LENS LED UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES: ANGLES 1' FINISH BREAK ALL CORNERS AND SHARP EDGES .030 MAX RNG 132 RETAINER FINISH TITLE: THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL 5 4 3 DRAWN: CHECKED: 3MM ROUND FRESNEL LOW PROFILE LENS DATE APPROVAL 6 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com SEE NOTES THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 7 VISUAL COMMUNICATIONS COMPANY, INC. POLYCARBONATE, UL 94-V2 PCB ASSEMBLY 8 MATERIAL DECIMALS .X .020 .010 .XX .XXX .005 SMU 4-23-10 DZ 4-23-10 SIZE SCALE: 12:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B SMC 170 XXX 001 SHEET 1 OF 1 1 A
SMC_170_GTP 价格&库存
很抱歉,暂时无法提供与“SMC_170_GTP”相匹配的价格&库存,您可以联系我们找货
SMC_170_GTP
    • 1+4.01760
    • 200+1.60920
    • 500+1.55520
    • 1000+1.52280
    SMC_170_GTP
    • 1+10.219711+1.32467
    • 10+7.1410010+0.92561
    • 100+5.27713100+0.68402
    • 500+4.45006500+0.57682
    • 1000+4.179231000+0.54171
    • 2000+3.949362000+0.51192
    • 5000+3.698305000+0.47937
    • 10000+3.5418910000+0.45910
    • 25000+3.3714825000+0.43701
    库存:15910
    SMC_170_GTP
