C12500_MIRA-M
C12500_MIRA-M
    LEDIL(芬兰)
    LENS RND MEDIUM 32.4MM CLEAR
C12500_MIRA-M 数据手册
PRODUCT DATASHEET C12500_MIRA-M MIRA-M ~30° medium beam TECHNICAL SPECIFICATIONS: Dimensions Height Ø 32.4 mm 14.7 mm Fastening ROHS compliant glue yes MATERIAL SPECIFICATIONS: Component Type Material Colour MIRA-M Single lens PC clear Finish ORDERING INFORMATION: Component C12500_MIRA-M » Box size: 480 x 280 x 300 mm Qty in box 840 MOQ MPQ 120 60 Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.3 1/8 PRODUCT DATASHEET C12500_MIRA-M See also our general installation guide: www.ledil.com/installation_guide Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET C12500_MIRA-M PHOTOMETRIC DATA (MEASURED): LED BXRA ES Star FWHM / FWTM 30.0° / 66.0° Efficiency 82 % LEDs/each optic 1 Light colour White Required components: LED V10 Gen6 FWHM / FWTM 35.0° / 72.0° Efficiency 77 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED CXA/B 15xx FWHM / FWTM 31.0° / 67.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHD-E/G FWHM / FWTM 28.0° / 65.0° Efficiency 85 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET C12500_MIRA-M PHOTOMETRIC DATA (MEASURED): LED MT-G FWHM / FWTM 28.0° / 62.0° Efficiency 83 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70 FWHM / FWTM 27.0° / 63.0° Efficiency 83 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 25.0° / 64.0° Efficiency 81 % LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 19.0° / 50.0° Efficiency 81 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET C12500_MIRA-M PHOTOMETRIC DATA (MEASURED): LED NFMW48xA FWHM / FWTM 21.0° / 53.0° Efficiency 82 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NSCxL036A FWHM / FWTM 28.0° / 60.0° Efficiency 80 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NSMx286M FWHM / FWTM 23.0° / 53.0° Efficiency 80 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 22.0° / 52.0° Efficiency 83 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET C12500_MIRA-M PHOTOMETRIC DATA (SIMULATED): LED VERO10 FWHM / FWTM 28.9° / 56.9° Efficiency 88 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED CLU710/711 FWHM / FWTM 54.0° / 88.0° Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5258 FWHM / FWTM 16.0° / 31.0° Efficiency 92 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON K4 FWHM / FWTM 26.0° / 58.0° Efficiency 86 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET C12500_MIRA-M PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 31.0° / 67.0° Efficiency 92 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET C12500_MIRA-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/12/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
C12500_MIRA-M 价格&库存
很抱歉,暂时无法提供与“C12500_MIRA-M”相匹配的价格&库存,您可以联系我们找货
C12500_MIRA-M
  • 10+10.1893010+1.27650
  • 25+10.0120925+1.25430
  • 75+9.8348975+1.23210
  • 150+9.74628150+1.22100
  • 400+9.56908400+1.19880
C12500_MIRA-M
  • 60+8.6387560+1.08225
  • 240+8.41725240+1.05450
  • 600+8.24004600+1.03230
  • 1500+8.062841500+1.01010
  • 2400+7.841332400+0.98235
C12500_MIRA-M
  • 60+7.3097160+0.91575
  • 180+7.13251180+0.89355
  • 300+7.08821300+0.88800
  • 1200+6.866701200+0.86025
  • 1800+6.689501800+0.83805
