FA10888_TINA-RS
FA10888_TINA-RS
    LEDIL(芬兰)
FA10888_TINA-RS 数据手册
PRODUCT DATASHEET FA10888_TINA-RS TINA-RS ~13° spot beam optimized for Nichia NS6x83. Assembly with holder and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 16.1 mm 11.1 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour TINA-RS Single lens PMMA clear TINA-N83-H-TAPE-WHT Holder PC white TINA-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component FA10888_TINA-RS » Box size: 470 x 240 x 105 mm Single lens Qty in box MOQ MPQ 2016 288 144 Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 4.1 1/8 PRODUCT DATASHEET FA10888_TINA-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET FA10888_TINA-RS PHOTOMETRIC DATA (MEASURED): LED MX-6 FWHM / FWTM 14.0° / 36.0° Efficiency 93 % Peak intensity 7.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NS6x83 FWHM / FWTM 17.0° / 39.0° Efficiency 94 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED TL1L4 FWHM / FWTM 13.0° / 28.0° Efficiency 90 % Peak intensity 10 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET FA10888_TINA-RS PHOTOMETRIC DATA (SIMULATED): LED XP-E2 FWHM / FWTM 10.0° / 20.0° Efficiency 92 % Peak intensity 22.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 14.0° / 25.0° Efficiency 92 % Peak intensity 13.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 16.0° / 32.0° Efficiency 89 % Peak intensity 8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 14.0° / 26.0° Efficiency 93 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET FA10888_TINA-RS PHOTOMETRIC DATA (SIMULATED): LED XT-E FWHM / FWTM 12.0° / 24.0° Efficiency 86 % Peak intensity 12.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 10.0° / 18.0° Efficiency 92 % Peak intensity 27 cd/lm LEDs/each optic 1 Light colour Red Required components: LED NV4WB35AM FWHM / FWTM 22.0° / 40.0° Efficiency 90 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 16.0° / 30.0° Efficiency 92 % Peak intensity 8.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET FA10888_TINA-RS PHOTOMETRIC DATA (SIMULATED): LED NVSW519A FWHM / FWTM 20.0° / 37.0° Efficiency 88 % Peak intensity 5.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 16.0° / 30.0° Efficiency 88 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Black FWHM / FWTM 10.0° / 20.0° Efficiency 89 % Peak intensity 20.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4716AS FWHM / FWTM 11.0° / 21.0° Efficiency 90 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET FA10888_TINA-RS PHOTOMETRIC DATA (SIMULATED): LED LH351C FWHM / FWTM 18.0° / 32.0° Efficiency 94 % Peak intensity 8.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET FA10888_TINA-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
FA10888_TINA-RS
物料型号:FA10888_TINA-RS
器件简介:TINA-RS是一款针对Nichia NS6x83 LED设计的13°聚光束角度优化的光学透镜,带有固定器和安装胶带。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 尺寸:直径16.1毫米,高度11.1毫米 - 固定胶带:符合RoHS标准 - 光学透镜:PMMA材质,透明 - 固定器:PC材质,白色 - 安装胶带:丙烯酸泡沫材质,黑色
功能详解:文档提供了不同LED型号的光度数据,包括CREE、TOSHIBA、NICHIA、LUMILEDS、OSRAM和SAMSUNG的LED,展示了它们的半高全宽角(FWHM/FWTM)、效率、峰值强度等参数。
应用信息:文档中未明确提供应用信息,但根据产品描述,适用于需要精确光束控制的照明应用。
封装信息:产品数据表提供了订购信息,包括每个组件的编号、每箱数量、最小起订量(MOQ)、最大起订量(MPQ)和每箱重量。
FA10888_TINA-RS 价格&库存
很抱歉,暂时无法提供与“FA10888_TINA-RS”相匹配的价格&库存,您可以联系我们找货
