25P-626A
25P-626A
    VCC
    Lens - Cap Amber, Clear 2802 or 2803 Socket, T-2 Slide Base Lamps, T-2 and T-3 1/4 Miniature Bayon...
25P-626A 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 2802 Series Relampable Incandescent Indicator Light Description and Features .810 DOME LENS BEZEL .630 FLAT LENS 0-.250THK. PANEL WHEN HEX NUT IS USED IN THIS MANNER. .530 .090 HEX NUT NYLON .810 ACROSS FLATS .840 .250-.340 THICK PANEL WHEN HEX. NUT IS REVERSED AS SHOWN .380±.020 11/16-27 THREAD BODY BLACK POLYESTER .187 QUICK CONNECT TERMINALS, NICKLE PLATED BRASS. All dimensions in inches. Lens Specifications Dome .438 9/16-27 THD. Fluted Dome Ø.625 .438 Ø.625 9/16-27 THD. Cylindrical .375 Ø.625 9/16-27 THD. Fluted Cylindrical .375 Ø.625 9/16-27 THD. All dimensions in inches. Ordering Information: For use with T-2 Slide Base (standard) lamps. Complete assembly consists of socket (2802), lamp, and lens (see chart below). Items supplied unassembled. Lamp, lens and socket must be ordered separately. Mounting: Supplied with polyester hex nut. Lens: Polycarbonate-threaded Body: Black polyester Terminals: Nickel plated brass Bezel: Black Lens Part No: Description Transparent dome 25P-306* Translucent dome 25P-307** Transparent fluted dome 25P-326* Transparent cylindrical 25P-606* 25P-607** Translucent cylindrical 25P-626* Transparent fluted cylindrical (*) R=Red, A=Amber, G=Green, C=Clear (**) R=Red, Y=Yellow, G=Green, W=White Note: For 120 volt applications, CML recommends the use of a slide base neon lamp, rather than an incandescent lamp. CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
25P-626A 价格&库存
很抱歉,暂时无法提供与“25P-626A”相匹配的价格&库存,您可以联系我们找货
25P-626A
