8
D
7
5
6
4
NOTES:
1.
MOUNTING: Mounts in a .281 .002 [ 7.13mm .05] panel hole on .375 [9.5mm] centers.
Panel thickness .031 [0.8mm] to .125 [3.18mm]. Panel hole should be deburred, but not
chamfered.
2.
ASSEMBLY: Insert lens through panel hole, slide RNG 268 retainer on back of lens. PCB
mounted LEDs slide into lens when the panel cover is closed or the PCB card is inserted into
the case.
3.
MATERIAL: Polycarbonate, UL 94-V2
GLO Series- Polycarbonate & Acrylic blend
Seal- TPE
4.
Meets NEMA 4 standards
5.
U.S. & Foreign Pat. Issued & Pend.
2
3
ECN#
1
1
REVISIONS
DESCRIPTION
ADD GLO SERIES. CHANGED ORDERING CODE
FORMAT
4-21-09
AZ
001
REVISED PER ECR111009AZ01
6/14/10
KH
REV.
DATE
INITIALS
D
RETAINER
(ORDER SEPARATELY)
C
C
RNG 268
.330
(8.38mm)
.300
(7.62mm)
.247
(6.27mm)
.281
(7.14mm)
B
B
.070
(1.78mm)
ORDERING CODE :
.260
(6.60mm)
CMS 322 XXX
MODEL
LENS COLOR
RTP
RED TRANSPARENT
ATP AMBER TRANSPARENT
GTP GREEN TRANSPARENT
BTP
BLUE TRANSPARENT
YTP YELLOW TRANSPARENT
CTP CLEAR TRANSPARENT
GLO WHITE TRANSLUCENT
A
8
7
LENS WITH
MOISTURE
SEAL
DISPAY PANEL
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN INCHES:
LED
ANGLES
1'
FINISH
MATERIAL
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
VISUAL COMMUNICATIONS COMPANY, INC.
SEE NOTES
DECIMALS
.X
.020
.010
.XX
.XXX .005
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
RNG 268
RETAINER
ASSEMBLY
PCB
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
6
5
4
3
DRAWN:
CHECKED:
5MM ROUND LOW PROFILE
FRESNEL LENS W/SEAL
DATE
APPROVAL
K.Howard 6/14/10
DZ 6/14/10
SIZE
SCALE: 6:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B CMS 322 XXX
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CMS_322_RTP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.294841+3.51651
- 10+19.7700310+2.54706
- 100+15.31219100+1.97274
- 500+13.35016500+1.71996
- 1000+12.710881000+1.63760
- 2000+12.169742000+1.56788
- 5000+11.580035000+1.49191
