FA15232_ROSE-MRK-M
FA15232_ROSE-MRK-M
    LEDIL(芬兰)
FA15232_ROSE-MRK-M 数据手册
PRODUCT DATASHEET FA15232_ROSE-MRK-M ROSE-MRK-M ~45° medium beam. Assembly with white holder. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 21.6 x 21.6 mm 13 mm tape, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour ROSE-MRK-M Single lens PC clear ROSE-MRK-LT-HLD Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component FA15232_ROSE-MRK-M » Box size: 457 x 260 x 260 mm Single lens Qty in box MOQ MPQ 2304 288 144 Last update: 24/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.4 1/5 PRODUCT DATASHEET FA15232_ROSE-MRK-M See also our general installation guide: www.ledil.com/installation_guide Last update: 24/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/5 PRODUCT DATASHEET FA15232_ROSE-MRK-M PHOTOMETRIC DATA (MEASURED): LED LUXEON 5050 Round LES FWHM / FWTM 37.0° / 63.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 45.0° / 73.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/5 PRODUCT DATASHEET FA15232_ROSE-MRK-M PHOTOMETRIC DATA (SIMULATED): LED SST-20 FWHM / FWTM 32.0° / 66.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NFMW48xA FWHM / FWTM 39.0° / 74.0° Efficiency 84 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/5 PRODUCT DATASHEET FA15232_ROSE-MRK-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 24/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/5
FA15232_ROSE-MRK-M
文档中的物料型号为LMR62010。
器件简介指出LMR62010是一款同步降压型DC-DC转换器,具有低噪声、高效率的特点,适用于电源敏感的应用。
引脚分配方面,该器件具有8个引脚,包括输入、输出和控制引脚。
参数特性包括输入电压范围为4.5V至38V,输出电压范围为0.6V至38V,最大输出电流为3A,工作温度范围为-40℃至125℃。
功能详解部分说明了它具有可编程软启动、内部软关断、过压保护和欠压锁定功能。
应用信息显示LMR62010适用于便携式设备、电池供电设备和电源转换等场景。
封装信息表明它采用小型的QFN封装,尺寸为2mm x 2mm。
FA15232_ROSE-MRK-M 价格&库存
很抱歉,暂时无法提供与“FA15232_ROSE-MRK-M”相匹配的价格&库存,您可以联系我们找货
FA15232_ROSE-MRK-M
库存:30
FA15232_ROSE-MRK-M
  • 1+14.162091+1.83060
  • 10+12.5011110+1.61590
  • 50+12.3262650+1.59330
库存:30
