10414
10414
    CARCLO
10414 数据手册
1 A B 2 3 4 5 6 7 8 9 10 CUSTOMER DRAWING SHEET 2 ONLY 11 12 13 14 15 D.C.N. NUMBER REV. DATE 1 01/06/08 1A 26/03/11 1B 05/12/11 16 17 18 19 20 CHECKED BY APPROVED BY DATE DATE DESCRIPTION FIRST ISSUE NAME dd/mm/yy NAME dd/mm/yy 03/11/1295 TYPO DIM CORRECTED NAME dd/mm/yy NAME dd/mm/yy 12/11/1322 DRAWING UPDATED WITH NEW DRW. STANDARDS AND NEW CARCLO OPTICS FORMAT FOR FULL DETAILS SEE D.C.N PW 16/07/12 MH 16/07/12 C D TOP VIEW E F PCB TOP VIEW 9.90± 0.10 -DRAFT == 8.00± 0.05 == 2.45± 0.10 4 OFF +DRAFT 9.90± 0.10 -DRAFT == 0.30± 0.10 TYP BOTTOM VIEW 1.4 4 OFF 8.00± 0.05 == C C 8.00± 0.05 == GLUE PADS 8.00± 0.05 == LED LENS POSITION MEDIUM FROSTED FINISH G H 1.00± 0.10 2 OFF 1.44±0.10 L PCB SAMPLE LAYOUT BASED ON A STANDARD THICKNESS 1.5mm + COATING 0.40± 0.10 2 OFF I 6.40 REF 1.10 x 0.7 DEEP LOCATION HOLE 2 OFF DIAGONAL 6.00±0.10 SCALE 4:1 SECTION C-C M NOTES: SCALE 1:1 1 - MATERIAL: POLYCARBONATE N 2 - FINISH: COMMERCIAL POLISH FOR ALL NON OPTICAL SURFACES. OPTICAL SURFACES ARE OPTICALLY POLISHED SCALE 4:1 Sheet 2 3 - OVERALL PART THICKNESS = SEE 3D FILE O Title 4 - COLOUR CLEAR 5 - GENERAL DRAFT 2° P 6 - SIMPLIFIED GEOMETRY SHOWN. NOT SUITABLE FOR OPTICAL RAYTRACE 10mm SQUARE WIDE FROSTED OPTIC FP Drawn by THIRD ANGLE PROJECTION GENERAL TOLERANCES UNLESS OTHERWISE STATED LINEAR ANGULAR 0 ± 0.0 ± 0.00 ± 0.25 0.1 0.05 0 ± 0.0 ± 0.00 ± of 2 1° 0.5 ° 0.1 ° Customer CARCLO CARCLO Optics CONFIDENTIAL: UNAUTHORISED COPYING, DISCUSSION & DISTRIBUTION PROHIBITED Scale DIMENSIONS IN mm CAD File 60527 Part N° 10414 Format Size Drw N° 60527 AS SPEC. A3
10414 价格&库存
很抱歉,暂时无法提供与“10414”相匹配的价格&库存,您可以联系我们找货
