8
D
7
5
6
4
NOTES:
MOUNTING: Mounts in a .250 .002 [ 6.35mm .05] panel hole on .375 [9.5mm] centers.
1.
Panel thickness .063 [1.6mm] to .125 [3.17mm]. Panel hole should be deburred, but not
chamfered.
2.
ASSEMBLY: Insert lens through panel hole, and insert LED into lens.
3.
MATERIAL: Polycarbonate, UL 94-V2
GLO Series- Polycarbonate & Acrylic blend
4.
U.S. & Foreign Pat. Issued & Pend.
2
3
ECN#
1
REVISIONS
DESCRIPTION
REV.
DATE
INITIALS
1
ADD GLO SERIES
1-6-09
JG
001
REVISED PER ECR111009AZ01
4-23-10
SMU
D
C
C
.430
10.92mm
.280
7.11mm
.250
6.35mm
B
B
.215
5.47mm
ORDERING CODE :
.125
3.18mm
CLF 280 XXX
MODEL
LENS COLOR
RTP
RED TRANSPARENT
ATP AMBER TRANSPARENT
GTP GREEN TRANSPARENT
BTP
BLUE TRANSPARENT
YTP YELLOW TRANSPARENT
CTP CLEAR TRANSPARENT
GLO WHITE TRANSLUCENT
A
8
7
DISPLAY
PANEL
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN INCHES:
ANGLES
1'
FINISH
MATERIAL
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
VISUAL COMMUNICATIONS COMPANY, INC.
POLYCARBONATE,
UL 94-V2
DECIMALS
.X
.020
.010
.XX
.XXX .005
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
LENS
LED
DATE
APPROVAL
THIRD ANGLE PROJECTION
ASSEMBLY
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
6
5
4
3
DRAWN:
CHECKED:
5MM ROUND STANDARD
HEIGHT FRESNEL LENS
SMU 4-23-10
DZ 4-23-10
SIZE
SCALE: 1:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B CLF 280 XXX
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CLF_280_ATP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+12.06193100+1.56028
- 500+5.99614500+0.77564
- 1000+5.083781000+0.65762
- 国内价格 香港价格
- 1+10.414091+1.34713
- 10+7.3101610+0.94561
- 100+5.41683100+0.70070
- 500+4.57255500+0.59149
- 1000+4.296301000+0.55575
- 2000+4.061822000+0.52542
- 5000+3.805845000+0.49231
- 10000+3.6463510000+0.47168
- 25000+3.4725525000+0.44920
