10770
10770
    CARCLO
    LENS 10MM SPOT TIR
10770 数据手册
B A C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm CUSTOMER DRAWING 1 GENERAL VIEW J E.C.N. DESCRIPTION 1 18-Aug-10 FIRST ISSUE 2 23-Mar-11 03/11/1294 ADD RECESS & DIM 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 X 6.00 2 I 1 2 4.95 5.15 4.95 SCALE 1:1 3 4.95 12.5 3 SECTION 4 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4.95 X-X 5.00 4 12.5 GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 X ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 5 TITLE 10mm IP66 SPOT E DRAWN 0.2 6 2.05 SEE DETAIL 1.81 E CHK'D DETAIL SCALE 8:1 DATE BB DATE MH APP'D DATE PW SCALE SIZE MATERIAL - UV STABILISED CLEAR POLYCARBONATE A B C D E F G 6 29-Nov-11 10770 CARCLO DRG. No. A3 H 29-Nov-11 CARCLO PART No. 4:1 7 18-Aug-10 60595 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 J E.C.N. DESCRIPTION 1 18-Aug-10 FIRST ISSUE 2 23-Mar-11 03/11/1294 ADD RECESS & DIM 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 1 2 2 2.6 LOCATION HOLE IN PCB 3 LED LENS POSITION 4.95 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 12.50 GENERAL TOLERANCES (UNLESS STATED) 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 4.95 2.1 LOCATION HOLE IN PCB X3 TITLE 10mm IP66 SPOT 12.50 DRAWN DATE BB CHK'D 6 DATE MH APP'D DATE PW SCALE 7 SIZE C D E F G H 29-Nov-11 6 29-Nov-11 10770 CARCLO DRG. No. A3 B 18-Aug-10 CARCLO PART No. 5:1 A 5 60595 I SHEET 3 OF 3 J 7
10770 价格&库存
很抱歉,暂时无法提供与“10770”相匹配的价格&库存,您可以联系我们找货
  • 1+19.454541+2.52168
  • 48+11.4715948+1.48694
  • 144+10.22145144+1.32490
  • 528+9.10467528+1.18014
  • 1008+8.664571008+1.12310
  • 2016+8.262612016+1.07100
  • 5040+7.824355040+1.01419
  • 10032+7.5534110032+0.97907
库存:379
