12079
12079
    CARCLO
12079 数据手册
B A C D E F G GENERAL VIEW ALL DIMENSIONS IN mm X 6.00 I ISS. DATE c 2011 CTP-COIL CUSTOMER DRAWING 1 H J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD RECESS DIMENSION & GENERAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 4.95 1 5.15 3.3 2 2 4.95 SCALE 1:1 4.95 25.7 3 12.5 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4 4 4.95 GENERAL TOLERANCES (UNLESS STATED) SECTION X-X LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 6.3 5.00 CUSTOMER 12.5 5 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CARCLO X 5 TITLE 10mm IP66 SPOT - with Location Pins & Flange 2.05 DRAWN 6 E E DETAIL SCALE 8:1 DATE MH APP'D 0.20 SEE DETAIL CHK'D 2.0 DATE BB DATE PW SCALE SIZE NOTES: A B C D E F G H 6 29-Nov-11 12079 CARCLO DRG. No. A3 1. MATERIAL - UV STABILISED CLEAR POLYCARBONATE 2. INCLUSIONS SPECIFIED TO BS ISO 10110. 29-Nov-11 CARCLO PART No. 4:1 7 12-Nov-10 60651 I SHEET 2 OF 3 J 7 A B C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 2 I J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD RECESS DIMENSIONS & GENERAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 03/11/1293 1 2 4.95 LED LENS POSITION 3.4 2.6 LOCATION HOLE IN PCB 3 3 9.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 GENERAL TOLERANCES (UNLESS STATED) 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 9.7 CUSTOMER CARCLO 5 TITLE 2.1 LOCATION HOLE IN PCB 10mm IP66 SPOT - with Location Pins & Flange DRAWN 3.4 DATE BB CHK'D 6 DATE MH APP'D DATE PW 4.95 SCALE 7 SIZE C D E F G H 29-Nov-11 6 29-Nov-11 12079 CARCLO DRG. No. A3 B 12-Nov-10 CARCLO PART No. 5:1 A 5 60651 I SHEET 3 OF 3 J 7
12079 价格&库存
很抱歉,暂时无法提供与“12079”相匹配的价格&库存,您可以联系我们找货
  • 1+15.843821+2.05624
