10771
10771
    CARCLO
    LENS 10MM DIFFUSED NARROW
10771 数据手册
B A C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm CUSTOMER DRAWING 1 GENERAL VIEW J E.C.N. DESCRIPTION 1 18-Aug-10 FIRST ISSUE 2 23-Mar-11 03/11/1294 ADD RECESS & DIM 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 X 6.00 2 I 1 2 4.95 5.15 4.95 SCALE 1:1 3 4.95 12.5 3 SECTION 4 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4.95 X-X 5.00 4 12.5 GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 X ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 5 TITLE 10mm IP66 NARROW & MEDIUM FROSTED OPTICS E DRAWN 0.2 6 2.05 SEE DETAIL 1.81 E CHK'D DETAIL SCALE 8:1 DATE BB DATE MH APP'D 7 A NARROW FROSTED 10771 MEDIUM FROSTED 10772 PW B SIZE C D E F G 29-Nov-11 see table CARCLO DRG. No. A3 H 6 CARCLO PART No. 4:1 MATERIAL - UV STABILISED CLEAR POLYCARBONATE 29-Nov-11 DATE SCALE FROSTED FINISH CARCLO PART No 18-Aug-10 60596 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 J E.C.N. DESCRIPTION 1 18-Aug-10 FIRST ISSUE 2 23-Mar-11 03/11/1294 ADD RECESS & DIM 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 1 2 2 2.6 LOCATION HOLE IN PCB 3 LED LENS POSITION 4.95 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 12.50 GENERAL TOLERANCES (UNLESS STATED) 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 4.95 2.1 LOCATION HOLE IN PCB X3 12.50 TITLE 10mm IP66 NARROW & MEDIUM FROSTED OPTICS DRAWN DATE BB CHK'D 6 A NARROW FROSTED 10771 MEDIUM FROSTED 10772 B PW SIZE E F G H 29-Nov-11 see table CARCLO DRG. No. A3 D 6 CARCLO PART No. 5:1 C 29-Nov-11 DATE SCALE FROSTED FINISH CARCLO PART No 18-Aug-10 DATE MH APP'D 7 5 60596 I SHEET 3 OF 3 J 7
10771 价格&库存
很抱歉,暂时无法提供与“10771”相匹配的价格&库存,您可以联系我们找货
      • 1+19.422761+2.51756
