10406
10406
    CARCLO
10406 数据手册
A ISS. DATE 2 25-Feb-09 B E.C.N. C DESCRIPTION E F 1 CUSTOMER DRAWING 19.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 111 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND DETAIL C SCALE 10:1 1.60 TEL: +44 1753 575011 FAX: +44 1753 811359 e-mail: design@carclo-optics.com} 0.7 SECTION A-A SCALE 2:1 GENERAL TOLERANCES (UNLESS STATED) 1.5 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 2.40 2 G c 2008 CARCLO ALL DIMENSIONS IN mm INNER CURVE MODIFIED 1 D ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 2 CUSTOMER 7.0 7.0 CARCLO 10.0 MAX GATE LENGTH 3 3.0 GATE WIDTH 130 DEGREE LED BUBBLE OPTIC 10.0 DRAWN 11.0 4 2.40 3D GENERAL VIEW SCALE 1:1 A A AJD A B MATERIAL: POLYCARBONATE C D E 10-Apr-08 DATE APP'D DATE SCALE CARCLO PART No. 2:1 SIZE 5 DATE CHK'D 0.85 DIAMOND DOWEL SEE DETAIL C 3 TITLE 4 10406 CARCLO DRG. No. A4 SHEET 60505 F 1 OF 2 G 5 A ISS. DATE 2 25-Feb-09 B E.C.N. C DESCRIPTION D E F G c 2008 CARCLO ALL DIMENSIONS IN mm INNER CURVE MODIFIED 1 1 CARCLO TECHNICAL PLASTICS (SLOUGH) 111 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS TEL: +44 1753 575011 FAX: +44 1753 811359 e-mail: design@carclo-optics.com} GENERAL TOLERANCES (UNLESS STATED) 2 LED LENS POSITION 19.7 GLUE PAD LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 2 CUSTOMER CARCLO 3 3 TITLE 130 DEGREE LED BUBBLE OPTIC DRAWN 4 12.50 PCB HOLE 2.5 PCB HOLE 2.5 PCB HOLE 7.0 5 B D APP'D DATE SCALE CARCLO PART No. SIZE 4 10406 CARCLO DRG. No. A4 E 10-Apr-08 DATE 5:1 11.0 SOLDER PAD RECESS C DATE CHK'D 12.5 PCB HOLE NOTE: THE CLOSEST THAT TWO OR MORE LENSES CAN BE PLACED TOGETHER WITHOUT OBSCURATION IS 27MM BETWEEN CENTRES. A AJD SHEET 60505 F 2 OF 2 G 5
10406
1. 物料型号:文档中提到了型号“10406”,这可能是物料的型号或部件编号。 2. 器件简介:文档描述了一个130度LED气泡光学元件,由Carclo Technical Plastics (Slough)设计和制造。 3. 引脚分配:文档中没有明确提到引脚分配,但提到了PCB胶垫和对齐孔的布局尺寸。 4. 参数特性:文档提供了一些公差信息,例如线性公差±0.1mm,角度公差±0.5°,以及更精细的公差±0.05mm和±0.1°。 5. 功能详解:文档详细描述了光学元件的视图和尺寸,包括最大门长度、门宽度、以及光学元件的3D视图。 6. 应用信息:文档指出,两个或更多的透镜之间的最近放置距离是中心之间27mm,以避免遮挡。 7. 封装信息:文档中提到了材料是聚碳酸酯,但没有提供封装的详细信息。
10406 价格&库存
很抱歉,暂时无法提供与“10406”相匹配的价格&库存,您可以联系我们找货
