10620
10620
    CARCLO
10620 数据手册
A ISS. DATE 1 25-Feb-09 B E.C.N. C DESCRIPTION E F 1 CUSTOMER DRAWING SECTION A-A SCALE 2:1 DIAMOND DOWEL DETAIL C SCALE 10:1 1.60 0.7 19.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 111 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 e-mail: design@carclo-optics.com} GENERAL TOLERANCES (UNLESS STATED) 1.5 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 2.40 2 10.0 MAX GATE LENGTH 3 3.0 GATE WIDTH CARCLO UNIFORM HEMI-SPHERICAL EMITTER BUBBLE OPTIC 7.3 DRAWN 4 2.40 A A AJD APP'D DATE SCALE CARCLO PART No. SIZE MATERIAL: POLYCARBONATE C D E 25-Feb-09 DATE 2:1 5 DIAMOND DOWEL SEE DETAIL C DATE CHK'D 0.85 B 2 3 TITLE 11.0 3D GENERAL VIEW SCALE 1:1 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER 7.0 7.0 A G c 2006 CARCLO ALL DIMENSIONS IN mm FIRST ISSUE 1 D 4 10620 CARCLO DRG. No. A4 SHEET 60570 F 1 OF 2 G 5 A ISS. DATE 1 25-Feb-09 B E.C.N. C DESCRIPTION D E F G c 2006 CARCLO ALL DIMENSIONS IN mm FIRST ISSUE 1 1 CARCLO TECHNICAL PLASTICS (SLOUGH) 111 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS TEL: +44 1753 575011 FAX: +44 1753 811359 e-mail: design@carclo-optics.com} GENERAL TOLERANCES (UNLESS STATED) 2 LED LENS POSITION 19.7 GLUE PAD OUTER LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 11.0 GLUE PAD INNER ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 2 CUSTOMER CARCLO 3 3 TITLE UNIFORM HEMI-SPHERICAL EMITTER BUBBLE OPTIC DRAWN 4 12.50 PCB HOLE 2.5 PCB HOLE 2.5 PCB HOLE B C APP'D DATE SCALE CARCLO PART No. SIZE E 4 10620 CARCLO DRG. No. A4 D 25-Feb-09 DATE 5:1 NOTE: THE CLOSEST THAT TWO OR MORE LENSES CAN BE PLACED TOGETHER WITHOUT OBSCURATION IS 27MM BETWEEN CENTRES. A DATE CHK'D 2.5 PCB HOLE 7.0 7.0 5 AJD SHEET 60570 F 2 OF 2 G 5
10620 价格&库存
很抱歉,暂时无法提供与“10620”相匹配的价格&库存,您可以联系我们找货
    • 5+12.24459
    • 50+10.77208
    • 250+9.67862
    • 500+9.38912
    库存:48
    10620
    库存:2
    10620
    • 1+19.458271+2.52053
    • 48+11.4737948+1.48626
    • 144+10.22341144+1.32429
    • 528+9.10642528+1.17960
    • 1008+8.666231008+1.12258
    • 2016+8.264202016+1.07051
    • 5040+7.825855040+1.01373
    • 10032+7.5548610032+0.97862
    库存:740
    相关技术文章
