CLB_300_YTP
CLB_300_YTP
    VCC
    CLB_300_YTP
CLB_300_YTP 数据手册
8 D 7 5 6 4 2 3 NOTES: 1. MOUNTING: Mounts in a .250 .002 [ 6.35mm .05] panel hole on .375 [9.5mm] centers. Panel thickness .031 [.8 mm] to .250 [6.35mm]. Panel hole should be deburred, but not chamfered. ASSEMBLY: Insert lens through panel hole, (for thin panels less than .188 [4.75mm] thick, slide 2. SPC 125 spacer on back of lens), and insert LED into lens. MATERIAL: Polycarbonate, UL 94-V2 3. GLO Series- Polycarbonate & Acrylic blend 4. U.S. & Foreign Pat. Issued & Pend. ECN# REV. 1 2 3 001 1 REVISIONS DESCRIPTION VARIOUS ADD GLO SERIES REMOVE RNG 268, ADD UL RATING TO MATERIAL REVISED PER ECR111009AZ01 DATE 5-91 1-6-09 9-16-09 4-23-10 INITIALS JS JG AZ SMU D SPACER (ORDER SEPARATELY) C C .430 10.92mm SPC 125 .250 6.35mm .280 7.11mm B B ORDERING CODE : .270 6.86mm .070 1.79mm CLB 300 XXX MODEL LENS COLOR RTP RED TRANSPARENT ATP AMBER TRANSPARENT GTP GREEN TRANSPARENT BTP BLUE TRANSPARENT YTP YELLOW TRANSPARENT CTP CLEAR TRANSPARENT GLO WHITE TRANSLUCENT A 8 7 DISPLAY PANEL UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES: ANGLES 1' FINISH MATERIAL BREAK ALL CORNERS AND SHARP EDGES .030 MAX 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com FINISH TITLE: SEE NOTES LED LENS VISUAL COMMUNICATIONS COMPANY, INC. POLYCARBONATE, UL 94-V2 DECIMALS .X .020 .010 .XX .XXX .005 SPC 125 SPACER DATE APPROVAL THIRD ANGLE PROJECTION PROPRIETARY AND CONFIDENTIAL ASSEMBLY 6 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 5 4 3 DRAWN: CHECKED: 5MM ROUND LOW PROFILE FRESNEL LENS SMU 4-23-10 DZ 4-23-10 SIZE SCALE: 1:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B CLB 300 XXX 001 SHEET 1 OF 1 1 A
CLB_300_YTP 价格&库存
很抱歉,暂时无法提供与“CLB_300_YTP”相匹配的价格&库存,您可以联系我们找货
CLB_300_YTP
    • 1+4.94640
    • 200+1.97640
    • 500+1.91160
    • 1000+1.87920
    CLB_300_YTP
      CLB_300_YTP
        CLB_300_YTP
        • 1+10.383921+1.34596
        • 10+7.2911110+0.94507
        • 100+5.40283100+0.70031
        • 500+4.56070500+0.59116
        • 1000+4.285181000+0.55544
        • 2000+4.051322000+0.52513
        • 5000+3.795995000+0.49204
        • 10000+3.6369110000+0.47142
        • 25000+3.4635725000+0.44895
        库存:637
        CLB_300_YTP
