10509
10509
    CARCLO
10509 数据手册
B A C D E F G ALL DIMENSIONS IN mm CUSTOMER DRAWING 9.3 20.0 4.6 I ISS. DATE c 2011 CTP-COIL X 1 H J E.C.N. DESCRIPTION 1 29-Apr-08 FIRST ISSUE 2 GATE SIZE INCREASED 12-Nov-08 10/08/1233 LEG PIN LENGTH REDUCED TO 1.5MM 10-Aug-11 08/11/1306 Gate tolerance updated 18-Jun-08 3 3A 1 2 12.0 8.0 2.7 2 3 5.3 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } SECTION 0.1 -0.1 GATE CROP 4 X-X 4 +0.3 6.9 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 13.9 X GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 TITLE 1.8 1.9 10mm TRIPLE OPTIC WIDE FROSTED 1.5 1.5 2.6 0.35 DRAWN DATE M.K. CHK'D DATE PW APP'D 6.0 6 DATE BB SCALE SEE DETAIL B B A SIZE MATERIAL - UV STABILISED CLEAR POLYCARBONATE SCALE 1:1 B C D E F G 10-Aug-11 6 10-Aug-11 10509 CARCLO DRG. No. A3 H 29-Apr-08 CARCLO PART No. 4:1 DETAIL SCALE 8:1 0.8 7 5 60524 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 J E.C.N. DESCRIPTION 1 06-May-08 FIRST ISSUE 2 GATE SIZE INCREASED LEG PIN LENGTH 12-Nov-08 10/08/1233 REDUCED TO 1.5MM 10-Aug-11 08/11/1306 Gate tolerance updated 18-Jun-08 3 3A 1 9.3 4.6 2 2 LED LENS POSITION X3 3 12.0 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND 6.7 2.6 GLUE PAD X3 } TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 GENERAL TOLERANCES (UNLESS STATED) 5 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER 1.3 2.1 LOCATION HOLE IN PCB X3 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 CARCLO 5 TITLE 10mm TRIPLE OPTIC WIDE FROSTED 6.9 DRAWN 13.9 CHK'D 6 DATE M.K. DATE PW APP'D DATE BB SCALE SIZE B C D E F G H 6 10-Aug-11 10509 CARCLO DRG. No. A3 A 10-Aug-11 CARCLO PART No. 5:1 7 06-May-08 60524 I SHEET 3 OF 3 J 7
10509 价格&库存
很抱歉,暂时无法提供与“10509”相匹配的价格&库存,您可以联系我们找货
库存:1240
10509
库存:515
10509
  • 1+20.089201+2.60395
  • 40+18.2094240+2.36029
  • 120+15.10193120+1.95750
  • 520+9.11626520+1.18164
  • 1000+9.025491000+1.16988
  • 2000+8.933932000+1.15801
  • 5000+8.845565000+1.14656
库存:4280
10509
    • 2+20.86413
    • 10+20.40592
    • 20+19.96854
    库存:158
