LLNS-1T08-H
LLNS-1T08-H
    AMSOSRAM(艾迈斯半导体)
    LENS TIR W/HLDR NARROW SPOT LZC
LLNS-1T08-H 数据手册
Narrow Spot TIR Lenses for LZC Emitter Family LLNS-1T08-H LLNS-3T08-H Key Features  Narrow Spot Total Internal Reflection (TIR) optics specifically designed for LED Engin LZC 12-die emitter family o o LLNS-1T08-H: 9 FWHM for mono-color emitters o LLNS-3T08-H: 13 FHWM for multi-color emitters o TM  Maximum Lux on Target  Provides the highest quality and quantity of light in a beam  Smooth light gradient eliminates hot spots and rings and minimizes glare for superior illumination and lumens in beam  UL-rated optical grade PMMA lens material allows use of high current and temperature conditions  Lenses are available standard with holder that mount easily onto LuxiGen LZC MCPCBs  Simple fastening of holder to MCPCB with appropriate adhesive, e.g. epoxy or polyurethane based Typical Applications  Architectural lighting  Stage and Studio lighting  Down lighting  Accent lighting  Track lighting Description The Narrow Spot TIR lenses family coupled with the compact, high-flux density LZC LuxiGen emitter family opens up new applications in stage and studio, architectural and down lighting. The TIR lens collimates the LED light into efficient, well-controlled light beams that maximize the usable lumens in the target area. Not only does this lighting solution provide the throw or distance required for these lighting applications, it does so with a smooth, high quality beam of superior intensity uniformity, color over angle mixing, and with an absence of discomfort glare or shadows. Optical Specification On-axis 5 intensity cd/lm degrees degrees Optical 4 efficiency % LLNS-1T08-H 9 27 86 14.6 LLNS-3T08-H 13 33 87 7.7 Part number 1 Beam angle 2 Field angle 3 Notes: 1. Lenses can also be ordered without the holder. Replace –H with –O for this option. 2. Beam angle is defined as the full width at 50% of the max intensity (FWHM). 3. Field angle is defined as the full width at 10% of the max intensity. 4. Optical efficiency is defined as the ratio between the incoming flux and the outgoing flux. 5. On-axis intensity is defined as the ratio between the total input lumen and the intensity in the optical center of the lens. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED. LLNS-1T08-H, LLNS-3T08-H (1.0-04/10/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Typical Relative Intensity over Angle 100% 90% 80% LLNS-1T08-H Relative Intensity 70% LLNS-3T08-H 60% 50% 40% 30% 20% 10% 0% -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 Angle (degrees) 30 40 50 60 70 80 90 General Characteristics Symbol Value Rating Unit Height from Seating Plane 51.0 Typical mm Diameter 84.0 Typical mm Mechanical Material Lens PMMA Holder Polycarbonate Optical 1 Transmission (>90%) λ 410-1100 Min-Max. nm Storage Temperature Tstg -40 ~ +110 Min-Max. °C Operating Temperature Tsol -40 ~ +110 Min-Max. °C Environmental Notes: 1. It is not recommended to use a UV emitter with this lens due to lower transmission at wavelengths < 410nm. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED. 2 LLNS-1T08-H, LLNS-3T08-H (1.0-04/10/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Mechanical dimensions Lens with holder COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED. Lens only 3 LLNS-1T08-H, LLNS-3T08-H (1.0-04/10/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Assembly Instruction Lens holders can be assembled to the PCB using an epoxy or polyurethane-based adhesive (example: Dow Corning 3145 RTV). Cyanoacrylate (superglue) adhesive should not be used to avoid contamination of the lens (blooming of the epoxy). When integrating the lens into a fixture without the lens holder, special attention is needed to maintain the distance between the lens bottom and the emitter top. Variation in this distance will result in variation of the beam profile. See mechanical detail B. on previous page. Lens Cleaning Use a lint-free soft cloth to dust off the lens. For deeper cleaning a solution of neutral detergent (example: dishwashing soap) can be used. Do not use any solvents or abrasive liquid/fabric. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED. 4 LLNS-1T08-H, LLNS-3T08-H (1.0-04/10/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com Company Information LED Engin, based in California’s Silicon Valley, develops, manufactures, and sells advanced LED emitters, optics and light engines to create uncompromised lighting experiences for a wide range of entertainment, architectural, general lighting and specialty applications. LuxiGen™ multi-die emitter and secondary lens combinations reliably deliver industry-leading flux density, upwards of 5000 quality lumens to a target, in a wide spectrum of colors including whites, tunable whites, multi-color and UV LEDs in a unique patented compact ceramic package. Our TM LuxiTune series of tunable white lighting modules leverage our LuxiGen emitters and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior in-source color mixing, allows for a previously unobtainable freedom of design wherever high-flux density, directional light is required. LED Engin is committed to providing products that conserve natural resources and reduce greenhouse emissions. LED Engin reserves the right to make changes to improve performance without notice. Please contact sales@ledengin.com or (408) 922-7200 for more information. COPYRIGHT © 2013 LED ENGIN. ALL RIGHTS RESERVED. 5 LLNS-1T08-H, LLNS-3T08-H (1.0-04/10/13) LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com
LLNS-1T08-H 价格&库存
很抱歉,暂时无法提供与“LLNS-1T08-H”相匹配的价格&库存,您可以联系我们找货
