12086
12086
    CARCLO
    LENS 10MM ELLIPITICAL TIR
12086 数据手册
B A C D E F G H ISS. DATE c 2011 CTP-COIL CUSTOMER DRAWING 1 ALL DIMENSIONS IN mm X GENERAL VIEW I 3.3 J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD DIMENSION RECESS & GENERAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 1 6.00 5.15 2 1.65 2 4.95 SCALE 1:1 4.95 0.3 3 25.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND 4.95 12.5 3 TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4 4 4.95 GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 5.00 SECTION X-X RIPPLE SURFACE 5 CUSTOMER X CARCLO 6.3 10mm IP66 LINEAR ELLIPTICAL - with Location Pins & flange DRAWN E 2° 0.2 2.05 B C E F H 29-Nov-11 6 29-Nov-11 12086 CARCLO DRG. No. A3 G 12-Nov-10 CARCLO PART No. SIZE DETAIL SCALE 8:1 D PW 5:1 E A DATE SCALE 2.0 MATERIAL - UV STABILISED CLEAR POLYCARBONATE DATE MH APP'D 7 DATE BB CHK'D 0.8 SEE DETAIL 5 TITLE 12.5 6 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 60656 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD RECESS DIMENSION & GENERAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 1 2 2 4.95 LED LENS POSITION 3.4 2.6 LOCATION HOLE IN PCB 3 3 9.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 GENERAL TOLERANCES (UNLESS STATED) 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 9.7 CUSTOMER CARCLO 5 5 TITLE 10mm IP66 LINEAR ELLIPTICAL - with Location Pins & flange 2.1 LOCATION HOLE IN PCB DRAWN 3.4 6 CHK'D 4.95 DATE BB DATE MH APP'D DATE PW SCALE SIZE B C D E F G H 6 29-Nov-11 12086 CARCLO DRG. No. A3 A 29-Nov-11 CARCLO PART No. 5:1 7 12-Nov-10 60656 I SHEET 3 OF 3 J 7
12086 价格&库存
很抱歉,暂时无法提供与“12086”相匹配的价格&库存,您可以联系我们找货
