8
D
7
5
6
4
NOTES:
MOUNTING: Mounts in a .281 .002 [ 7.13mm .05] panel hole on .375 [9.5mm] centers.
1.
Panel thickness .031 [0.8mm] to .250 [6.35mm]. Panel hole should be deburred, but not
chamfered.
2.
ASSEMBLY: Insert lens through panel hole, slide RNG 268 retainer on back of lens. PCB
mounted LEDs slide into lens when the panel cover is closed or the PCB card is inserted into
the case.
MATERIAL: Polycarbonate, UL 94-V2
3.
4.
U.S. & Foreign Pat. Issued & Pend.
2
3
ECN#
1
REV.
REVISIONS
DESCRIPTION
001
REVISED PER ECR111009AZ01
DATE
INITIALS
4-23-10
SMU
D
RETAINER
(ORDER SEPARATELY)
C
C
.330
8.38mm
RNG 268
.300
7.62mm
.281
7.14mm
B
B
.260
6.6mm
ORDERING CODE :
CMC 313 XXX
MODEL
RTP
ATP
GTP
BTP
YTP
CTP
A
LENS COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
LENS
DISPAY PANEL
LED
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN INCHES:
ANGLES
1'
FINISH
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
6
190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA
Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com
FINISH
TITLE:
PCB
PROPRIETARY AND CONFIDENTIAL
5
4
3
DRAWN:
CHECKED:
5MM ROUND PLAIN
DIFFUSED LENS
DATE
APPROVAL
THIRD ANGLE PROJECTION
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
7
POLYCARBONATE,
UL 94-V2
SEE NOTES
RNG 268
RETAINER
ASSEMBLY
8
MATERIAL
DECIMALS
.X
.020
.010
.XX
.XXX .005
SMU 4-23-10
DZ 4-23-10
SIZE
SCALE: 1:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B CMC 313 XXX
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“CMC_313_BTP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 275+3.83845275+0.49722
- 500+3.75708500+0.48668
- 1000+2.498441000+0.32364
