131A-304R
131A-304R
    VCC
    131A-304R
131A-304R 数据手册
engineered to light up your design www.vcclite.com 1.800.522.5546 CLIPLITE Midget Flange Relampable Indicator Lights Description and Features Standard 15/32-32 THD. Watertight .781 15/32-32 THD. .770 .085 .032 Ø.650 Ø.550 5131-038 5/16-32 THD. 5139-038 O-RING 5/16-32 THD. .421 Ø.438 131A-30XX .438 Ø.578 139A-40XX All dimensions in inches. The Chicago Miniature Lamp Midget Flange Indicator Lights are versatile, industry standard, front panel indicator lights capable of accepting any T-1 3/4 midget flange base lamp. These high quality indicators provide reliable service in a vast array of commercial and military applications (conforming to MIL-L-3661). Lamps are easily replaced from the front panel. These indicator lights are available in both a standard configuration and a watertight configuration providing reliable status indication in the most demanding of environments. The lamp is not included with this indicator light; please order the required lamp separately. Specifications Standard 131A-303R 131A-303A 131A-303G 131A-303C 131A-304R 131A-304Y 131A-304G 131A-304W Watertight 139A-403R 139A-403A 139A-403C 139A-404R 139A-404Y 139A-404G 139A-404W Description Transparent Red Transparent Amber Transparent Green Transparent Clear Translucent Red Translucent Yellow Translucent Green Translucent White .484, 5131 Type has a keyed flange anti-rotation feature, 5139 Type features a flat "D" hole mounting .750 Mounting Centers: Maximum Panel Thickness: 5131 type - .265, 5139 type - .188 Black anodized aluminum Housing/Material: Terminals: Tin plated brass, center contact terminal marked + Hex Nut: Chrome treated steel Lockwasher: Chrome treated steel Lens: High temperature lexan Lens Shank: Nickel plated brass Electrical rating: up to 30 Volts, up to 2 Watt Mounting Hole: CML and Chicago Miniature Lamp are registered trademarks of Visual Communications Company, LLC.
131A-304R
物料型号: - 标准配置型号包括131A-303R(透明红)、131A-303A(透明琥珀)、131A-303G(透明绿)等。 - 防水配置型号包括139A-403R(透明红)、139A-403A(透明琥珀)等。
器件简介: - 这些指示灯是多功能的,符合行业标准,能够接受任何T-1 3/4小帽座灯。
引脚分配: - 引脚分配未在文档中明确说明,但提到了中心接触端子标记。
参数特性: - 标准和防水配置的指示灯具有不同的型号,例如透明红和透明琥珀。 - 有键槽的法兰防旋转特性,以及平板"D"孔安装。
功能详解: - 这些指示灯能够在多种商业和军事应用中提供可靠的服务,并且可以从前面更换灯泡。
应用信息: - 适用于广泛的商业和军事应用,符合MIL-L-3661标准。
封装信息: - 包括黑色阳极氧化铝外壳、镀锡黄铜端子、镀铬钢六角螺母和锁垫圈、高温Lexan透镜、镀镍黄铜透镜柄。 - 电气额定值:最高30伏特,最高2瓦特。
131A-304R 价格&库存
很抱歉,暂时无法提供与“131A-304R”相匹配的价格&库存,您可以联系我们找货
