OP-5LN1-0451
OP-5LN1-0451
    LIGHTINGSCIENCE
OP-5LN1-0451 数据手册
Data Sheet Light Engine Accessories ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  Introduction: Light Engine Accessories. .........................................................3 Heat Sink Selection and Assembly Recommendations........................................3 Contents Light Engine Accessories of ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Table Atlas™ NT-4000 Heat Sinks Mechanical Specifications and Compatibility.............................................4 Thermal Resistance. ................................................................................4 Temperature Rise Over Ambient...............................................................4 Titan™ NT-5000 Heat Sink HS-5100-0346 Mechanical Specifications........................................................................5 Thermal Resistance. ................................................................................5 Temperature Rise Over Ambient...............................................................5 Titan™ NT-5000 Heat Sink HS-5200-0493 Mechanical Specifications........................................................................6 Thermal Resistance. ................................................................................6 Temperature Rise Over Ambient...............................................................6 TitanTurbo™ NT-5000 Heat Sinks Mechanical Specifications........................................................................7 Thermal Resistance. ................................................................................7 Temperature Rise Over Ambient...............................................................8 Optics Atlas NT-4000 OP-Series Optical Characteristics...........................................................................8 Optical Performance, Daylight and Warm. ..............................................8 Optical Performance, RGB.....................................................................8 Narrow Optic Mechanical Dimensions......................................................9 Optic Relative Luminous Intensity Curves, Daylight and Warm White...... 9 Typical Illuminance Characteristics.......................................................10 Relative Luminous Intensity Curves, RGB..............................................10 Typical Illuminance Characteristics, RGB ............................................ 11 Titan NT-5000 OP-Series Optical Characteristics......................................................................... 11 Optical Performance, Daylight and Warm White...................................12 Optical Performance, RGB...................................................................12 Optic Mechanical Dimensions & Mounting Hole Patterns. .....................13 Optic Relative Luminous Intensity Curves..............................................14 Illuminance Characteristics...................................................................15 Interconnects Atlas™ Soldering EZ-Connect Board to Light Engines........................16 Atlas™ NT-4000 EZ-Connect Board....................................................17 Atlas™ NT-4000 Wiring Harness. ........................................................17 Titan™ NT-5000 Wiring Harness..........................................................17 Patents, Connections, Assembly, Packaging, and Notes.................................18 RoHS and Warranty......................................................................................18  Introducing Lamina’s Light Engine Accessories Lamina® is pleased to offer you these accessories with our array of award winning LED products. These parts have been carefully chosen and developed to work with our LED light engines to help you quickly prove out your design and even go to market if you find them appropriate. Our Application Engineers are ready to help you select the right parts for your project. Please do not hesitate to give us a call as we are eager to work with you. Heat Sink Selection Radial Shaped for design flexibility Drilled and tapped for ease of assembly Anodized for enhanced thermal performance Designed for a wide range of mounting positions Assembly Recommendations Lamina’s light engines are designed to attach to heat sinks using screws with thermal grease in the joint or by using conductive epoxy. All Lamina® heat sinks are drilled and tapped to accept the recommended fasteners. More information on recommended attachment methods can be found in Lamina’s Connection Guide for Lamina’s LED Light Engines at www.laminalighting.com. Introduction Lamina’s light engines should maintain LED die junction temperatures at or below maximum rated temperatures. Lamina’s LED light engines provide very efficient transfer of heat from the individual LED die to the heat sink. Additionally, a heat sink with sufficient cooling capacity must be selected to maintain the LED die junction below the maximum rated temperature. Lamina’s heat sinks have been sized for Lamina’s standard products and to accommodate a range of desired operating conditions. Proper heat sink sizing is determined by a number of factors, including those listed below: • • • • • Power Dissipated (Watts) - Determined by the light engine part number and associated drive parameters chosen for operating the LED Light Engine. • Ambient Conditions - Ambient temperature, free or forced convection of air, etc. • Thermal Path - Thermal interface material, light engine attachment method, surface area and conductivity of fixture housing the heat sink. • Desired Lifetime and Lumen Maintenance - Lower LED junction temperatures result in longer lifetimes and higher light output over life. Increasing heat sink size will generally help to lower LED operating temperatures. Applications • Desired Light Output - LED luminous output is affected by the temperature at which the LEDs operate. Red and amber are more affected than blue, green and white. Increasing heat sink size will generally help to lower LED operating temperatures and result in higher light output. Lamina® developed a selection of radial heat sinks to enable easy and rapid prototyping of designs with Lamina’s light engines. These heat sinks have been designed to maximize the thermal performance of high brightness LED light engines while allowing design flexibility. Lamina® heat sinks are: • Designed for optimal thermal performance with Lamina’s AtlasTM NT-4000 and TitanTM NT-5000 families of light engines ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  Atlas™ Heat Sink Mechanical Specifications NT-4000 Figure 1. Lamina’s heat sinks come in four different thicknesses (“A” Dimension), from 0.5” (12.7 mm) to 1.5” (38.1 mm) thick. Table 1 lists the applicable sizes for Lamina’s standard AtlasTM NT-4000 products. Table 1. Note: 1. For the higher wattage red and amber light engines additional forced convection is necessary. Additional convection can be achieved by attaching a CPU style fan to the back of the heat sink, connecting the fan to the paddles of the heat sink. NT-4000 Heat Compatibility Heat Sink Part Number Dimension “A” HS-4050-0345 0.5” HS-4075-0345 0.75” HS-4100-0345 1.0” HS-4150-0345 1.5” Note 2. Applicable heat sinks when operated at rated LED light engine power, 25°C ambient and unrestricted convection. Atlas™ Heat Sink Thermal Resistance NT-4000 18 Thermal Resistance (deg/Watt) Figure 2. Heat Sink Thickness 16 0.50" (1.27 cm) 14 0.75" (1.90 cm) 12 1.0" (2.54 cm) 10 1.5" (3.81 cm) 8 6 4 2 0 0 2 4 6 8 10 12 14 16 18 20 Power Dissipated (W) Atlas™ Heat Sink Temperature Rise Over Ambient NT-4000 Heat Sink Temperature Rise Over Ambient (degC) 120 Figure 3. 100 80 60 Heat Sink Thickness 40 0.50" (1.27 cm) 0.75" (1.90 cm) 20 1.0" (2.54 cm) 1.5" (3.81 cm) 0 0 ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 5 10 15 20 Power Dissipated (W) Light Engine Accessories  Titan™Heat Sink Mechanical Specifications NT-5000 (HS-5100-0346) Figure 4. Units: Inches [millimeters] Titan™ Heat Sink Thermal Resistance NT-5000 (HS-5100-0346) 6 Thermal Resistance (Deg C/Watt) 5 Figure 5. 4 3 2 1 0 0 10 20 30 40 50 Power Dissipated (Watts) Titan™ Heat Sink Temperature Rise Over Ambient NT-5000 (HS-5100-0346) Figure 6. Heat Sink Temperature Rise Over Ambient (Deg C) 80 70 60 50 40 30 20 10 0 0 5 10 15 20 25 30 35 40 45 50 Power Dissipated (Watts) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  Titan™Heat Sink Mechanical Specifications NT-5000 (HS-5200-0493) Figure 7. Units: Inches [millimeters] Titan™ Heat Sink Thermal Resistance NT-5000 (HS-5200-0493) Thermal Resistance: Steady State, Natural Convection in Free Air 2.00 Figure 8. 1.90 Thermal Resistance (degC/W) 1.80 1.70 1.60 1.50 1.40 1.30 1.20 1.10 1.00 0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 Applied Power to LED (W) Titan™Heat Sink Temperature Rise Over Ambient NT-5000 (HS-5200-0493) Temperature Rise Above Ambient: Steady State, Natural Convection in Free Air Figure 9. 70.0 Temperature Rise (degC) 60.0 50.0 40.0 30.0 20.0 10.0 0.0 0.0 5.0 10.0 15.0 20.0 25.0 30.0 35.0 40.0 45.0 50.0 Applied Power to LED (W) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  TitanTurbo™ Heat Sink Mechanical Specifications NT-5000 (HS-5410-0537), (HS-5430-0537), and (HS-543R-0537) Figure 10. Units: Inches [millimeters] TitanTurbo™ Heat Sink Thermal Resistance Heat Sink Thermal Resistance NT-5000 (HS-5410-0537) Figure11. 1.30 Thermal Resistance (degC/W) 1.20 HS-5410-0537 1.10 1.00 0.90 0.80 0.70 0.60 0.50 0 5 10 15 20 25 30 35 40 45 Applied Power to LED (W) Heat Sink Thermal Resistance NT-5000 (HS-5430-0537) and (HS-543R-0537) Figure 12. 0.85 HS-5430-0537 0.80 Thermal Resistance (degC/W) HS-543R-0537 0.75 0.70 0.65 0.60 0.55 0.50 10 15 20 25 30 35 40 45 50 55 60 Applied Power to LED (W) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  TitanTurbo™ Heat Sink Temperature Rise Over Ambient Temperature Rise Above Ambient and (HS-543R-0537) NT-5000 (HS-5410-0537), (HS-5430-0537), Figure 13. 45 40 Temperature Rise (degC) 35 30 25 20 15 HS-5410-0537 HS-5430-0537 10 HS-543R-0537 5 0 - 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80 Applied Power to LED (W) Atlas™ NT-4000 OP Series Table 2. Lamina® now offers optics with narrow, medium and wide beam distributions designed for the Atlas product family. Lamina®, working with Fraen Corporation, has developed optics and optic holders based on Fraen’s popular FHS series. Atlas optics are designed to produce homogeneous beam distributions with high collection efficiencies. The optic holders are designed to attach to Lamina’s EZ-Connect Board. Optical Characteristics General Characteristics Lens Material Optical Grade PMMA Holder Material PC ABS Operating Ambient Temperature Range -10°C / +80°C Storage Temperature Range -10°C / +80°C Optical Performance Warm White (NT-42D1-0425) and Daylight White (NT-42D0-0426) Lens Part Number Type of Lens Typical Total Beam Divergence [1] Fig. # Typ. Efficiency OP-4LN2-0492 Narrow Beam 17° 9 75% OP-4FM1-0442 Medium Beam 32° 10 86% OP-4FW1-0441 Wide Beam 38° 10 84% Typical Total Beam Divergence [1] Fig. # Typ. Efficiency Table 3. Notes: 1. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. Optical Performance RGB (NT-43F0-0424) Lens Part Number Type of Lens OP-4LN1-0457 Narrow Beam 17° 9 73% OP-4FM1-0442 Medium Beam 34° 10 86% OP-4FW1-0441 Wide Beam 38° 10 84% ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Table 4. Notes: 1. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. Light Engine Accessories  Atlas™ Optic Mechanical Dimensions NT-4000 Narrow (OP-4LN1-0457 and (OP-4LN2-0492) Figure 14. Units: Inches [millimeters] NT-4000 Medium (OP-4FM1-0442) and Wide OP-4FW1-0441 Figure 15. Units: Inches [millimeters] Atlas™ Optic Relative Luminous Intensity Curve Warm White (NT-42D1-0425) and Daylight White (NT-42D0-0426) Figure 16. 1 0.9 OP-4LN1-0492 Narrow OP-4FM1-0442 Medium OP-4FW1-0441 Wide 0.8 Relative Luminous Intensity 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories  Typical Illuminance Characteristics Illuminance (Lux) Distance from Source [M] Drive Current (mA) Product 1 Table 5. Illuminance (fc) Distance from Source [FT] 2 5 10 3.3 6.6 16.4 32.8 Warm White Light Engine - NT-42D1-0425 700 1228 OP-4LN2-0492 - Narrow 1050 1627 700 351 OP-4FM1-0442 - Medium 1050 463 700 228 OP-4FW1-0441 - Wide 1050 301 307 407 88 115 57 75 49 65 14 19 9 12 12.3 16.3 3.5 4.6 2.3 3.0 114 151 33 43 21 28 29 38 8 11 5 7 5 6 1 2 1 1 1.1 1.5 0.3 0.4 0.2 0.3 Daylight White Light Engine - NT-42D0-0426 700 1921 OP-4LN2-0492 - Narrow 1050 2435 700 549 OP-4FM1-0442 - Medium 1050 696 700 356 OP-4FW1-0441 - Wide 1050 452 480 609 137 174 89 113 77 97 22 28 14 18 19.2 24.4 5.5 7.0 3.6 4.5 179 225 51 65 33 42 45 57 13 16 8 11 7 9 2 3 1 2 1.8 2.3 0.5 0.6 0.3 0.4 Atlas™ Relative Luminous Intensity Curves RGB (NT-43F0-0424) Light Engine with Narrow Optic 1 Figure 17. Red Grn Blu 0.9 0.8 Relative Luminous Intensity 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) Atlas™ Relative Luminous Intensity Curves Figure 18. RGB (NT-43F0-0424) Light Engine with Medium Optic 1 0.9 Red Green Blue Relative Luminous Intensity 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 10 Atlas™ Relative Luminous Intensity Curves RGB (NT-43F0-0424) Light Engine with Wide Optic 1 Figure 19. 0.9 Red Green Blue Relative Luminous Intensity 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) Typical Illuminance Characteristics RGB (NT-43F0-0424) Light Engine Product Drive Current (mA) Illuminance (Lux) Distance from Source [M] Illuminance (fc) Distance from Source [F] 1 2 5 10 3.3 6.6 16.4 32.8 350 525 376 545 94 136 15 22 3.8 5.4 35 51 9 13 1 2 0.3 0.5 350 525 350 525 775 1013 169 233 194 253 48 58 31 41 7 9 7.7 10.1 1.7 2.3 72 84 16 22 18 24 4 5 3 4 1 1 0.7 0.9 0.2 0.2 350 525 350 525 350 525 125 183 309 402 53 72 31 46 77 100 13 18 5 7 13 16 2 3 1.3 1.8 3.1 4.0 0.5 0.7 12 17 29 37 5 7 3 4 7 9 1 2 1 1 1 2 0.2 0.3 0.1 0.2 0.3 0.4 0.0 0.1 350 525 350 525 350 525 116 168 146 189 42 59 29 42 37 47 10 15 5 7 6 8 2 2 1.2 1.7 1.5 1.9 0.4 0.6 11 16 14 18 4 6 3 4 3 4 1 1 0.4 0.6 0.5 0.7 0.2 0.2 0.1 0.2 0.1 0.2 0.0 0.1 Table 6. OP-4LN1-0457 Narrow Red Green Blue OP-4FM1-0442 Medium Red Green Blue OP-4FW1-0441 Wide Red Green Blue ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 11 Titan™ NT-5000 Optic - OP Series Lamina’s TitanTM Series is available in 3050K Warm White, 4700K Daylight White and RGB. The Titan 3050K Warm White delivers 600+ lumens from a single point. Enhanced red and orange color spectrum and a CRI of 80 make this product ideal for incandescent and halogen replacements. The Titan RGB, through three independently controlled input and output channels (red, green and blue), produces any of 16,000,000 beautifully saturated and blended colors (including white with variable color temperature) from a single point source. Lamina® now offers optics with narrow, medium, and wide beam distributions designed for the NT-5000 product family. The optics were designed in collaboration with Transducin Optics, LLC. Each optic is supplied with an optic mount that is compatible with Lamina® heat sinks, interchangeable lens for medium and wide beam, and assembly instructions. Optical Characteristics Table 7. General Characteristics Lens Material Optical Grade PMMA Holder Material ABS Operating Ambient Temperature Range -10°C / +50°C Storage Temperature Range -10°C / +50°C Optical Performance Warm White (NT-52D0-0429) and Daylight White (NT-52D1-0430) Lens Part Number Type of Lens Typical Total Beam Divergence [1] Figure # Typ. Efficiency OP-5LN1-0451 Narrow Beam 9 16 72% OP-5LN2-0445 Narrow 24 15 82% OP-5LM3-0455 Medium Beam 35 15 82% OP-5LW4-0456 Wide Beam 48 15 82% OP-5LN1-0499 Narrow Beam 11 18 70% Table 8. Notes: 1. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. Optical Performance, RGB (NT-53F0-0428) Lens Part Number Type of Lens Typical Total Beam Divergence [1] Figure # Typ. Efficiency OP-5LN2-0445 Narrow 24 15 82% OP-5LM3-0455 Medium Beam 35 15 82% OP-5LW4-0456 Wide Beam 48 15 82% OP-5LN1-0499 Narrow Beam 11 18 70% ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Table 9. Notes: 1. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. Light Engine Accessories 12 Titan™ Optic Mechanical Dimensions OP-5LN2-0445, OP-5LM3-0455 and OP-5LW-0456 Figure 20. OP-5LN1-0451 Figure 21. Mounting Hole Patterns OP-5LN1-0451 Figure 22. ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 13 Titan™ Optic Mechanical Dimensions OP-5LN1-0499 Figure 23. Mounting Hole Patterns OP-5LN1-0499 Figure 24. Titan™ Relative Luminous Intensity Curves Warm White (NT-52D1-0430) and Daylight White (NT-52D0-0429) Optics Figure 25. 1 0.9 0.8 OP-5LN1-0451 Narrow OP-5LN2-0445 Med-Narrow Relative Luminous Intensity 0.7 OP-5LM3-0455 Medium OP-5LW4-0456 Wide 0.6 0.5 0.4 0.3 0.2 0.1 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 14 OP-5LN2-0445 Med-Narrow Luminous Intensity Curves RGB Optic (NT-53F0-0428) Figure 26. 1 OP-5LN2-0445 Red OP-5LN2-0445 Grn OP-5LN2-0445 Blu 0.9 0.8 Relative Luminous Intensity 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) OP-5LW4-0446 Wide Luminous Intensity Curves RGB Optic (NT-53F0-0428) Figure 27. 1 OP-5LW4-0456 Red OP-5LW4-0456 Grn OP-5LW4-0456 Blu 0.9 0.8 Relative Luminous Intensity 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 -90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20 30 40 50 60 70 80 90 Angular Distribution (deg) Titan Typical Illuminance Characteristics TM Narrow Optic OP-5LN1-0451 Part Number Color NT-52D1-0430 Warm White NT-52D0-0429 Daylight White Drive Current (mA) 1050 1400 1050 1400 Illuminance (Lux) Distance from Source [M] Table 10. Illuminance (fc) Distance from Source [F] 1 2 5 10 3.3 6.6 16.4 32.8 3592 4621 5340 6336 898 1155 1335 1584 144 185 214 254 36 46 53 63 334 429 496 589 83 107 124 147 13 17 20 24 3 4 5 6 Narrow Optic OP-5LN2-0445 Part Number Color NT-52D1-0430 Warm White NT-52D0-0429 Daylight White NT-53F0-0428 RGB, Red RGB, Green RGB, Blue ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Drive Current (mA) 1050 1400 1050 1400 1050 1400 1050 1400 1050 1400 Illuminance (Lux) Distance from Source [M] Table 11. Illuminance (fc) Distance from Source [F] 1 2 5 10 3.3 6.6 16.4 32.8 2602 3447 3871 4594 1098 1571 1769 2298 507 690 551 862 968 1149 275 393 442 575 127 173 108 138 155 184 44 63 71 92 20 28 26 35 39 46 11 16 18 23 5 7 242 320 360 427 102 146 164 214 47 64 60 80 90 107 26 37 41 53 12 16 10 13 14 17 4 6 7 9 2 3 2.4 3.2 3.6 4.3 1.0 1.5 1.6 2.1 0.5 0.6 Light Engine Accessories 15 Medium Optic OP-5LM3-0455 Part Number Color NT-52D1-0430 Warm White NT-52D0-0429 Daylight White NT-53F0-0428 RGB, Red RGB, Green RGB, Blue Drive Current (mA) 1050 1400 1050 1400 1050 1400 1050 1400 1050 1400 Illuminance (Lux) Distance from Source [M] Table 12. Illuminance (fc) Distance from Source [F] 1 2 5 10 3.3 6.6 16.4 32.8 1408 1864 2094 2485 552 789 934 1214 247 336 352 466 523 621 138 197 234 304 62 84 56 75 84 100 22 32 37 49 10 14 14 19 21 25 5.5 7.9 9.3 12.1 2.5 3.4 131 173 195 231 51 73 87 113 23 31 33 43 47 58 13 18 22 28 6 8 5 7 8 9 2 3 4 5 1 1 1.3 1.7 1.9 2.3 0.5 0.7 0.9 1.1 0.2 0.3 Wide Optic OP-5LW4-0456 Product Color NT-52D1-0430 Warm White NT-52D0-0429 Daylight White NT-53F0-0428 RGB, Red RGB, Green RGB, Blue Drive Current (mA) 1050 1400 1050 1400 1050 1400 1050 1400 1050 1400 Illuminance (Lux) Distance from Source [M] Table 13. Illuminance (fc) Distance from Source [F] 1 2 5 10 3.3 6.6 16.4 32.8 924 1224 1374 1631 357 510 585 760 162 220 231 306 344 408 89 128 234 190 40 55 37 49 55 65 14 20 37 30 7 9 9.2 12.2 13.7 16.3 3.6 5.1 5.8 7.6 1.6 2.2 86 114 128 152 33 47 54 71 15 20 22 28 32 38 8 12 14 18 4 5 3 5 5 6 1 2 2 3 1 1 0.9 1.1 1.3 1.5 0.3 0.5 0.5 0.7 0.2 0.2 Atlas NT-4000 Soldering EZ-Connect Board to Lamina’s Light Engines TM Electrical connections may be made between a PWB and AtlasTM products with lead free solder (Sn96/Ag3.5/Cu0.5) using localized heating on the AtlasTM terminals. • Mounting holes for Lamina® Optics • Standard AMP connector • Mating color coded wiring harness available Figure 28. ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 16 Atlas EZ-Connect Board TM NT-4000 EZ-Connect Board (EZ-4000-0357) Figure 29. Atlas TM and Titan Wiring Harnesses TM Atlas™ NT-4000 EZ-Connect Wiring Harness (EZ-46WH-0345) Figure 30. Units: Inches [millimeters] The same wire harness is used for RGB and White parts. Connector reference AMP P/N 173977-6. Titan™ NT-5000 EZ-46WH-0354 Figure 31. Units: Inches [millimeters] The same wire harness is used for RGB and White parts. Connector reference Molex Header 87438-1043 and Crimp Terminal 87421-0000. ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 17 Patents, Connections, Assembly, and Packaging Patents Lamina’s light engines may be covered by pending patents and/or one or more of the following U.S. and/or International patents 5876536, 6709749 B, 595880, 6017642, 5565262, 5681444, 5653834, 5581876, 5847935, 5514451, 5747931, 5925203, 5725808, 5929510, 5858145, 5866240, 5953203, 6055151, 614076, 6011330, 6399230, 6914501, 6168490, 6191934, 614075, 6160469, 6300267, 6471805, 6518502, 6739047, 6720859, 6759940, 6518502, 6670856 B1, 6720859, 6713862 B2, WO 00/47399, WO 00/26152, WO 98/19339, 5082804, ZL99808762.9, 69623930, 69628549, 69629572, 805785, 69628549, 843621, 932500, 805785, 812258, 843621, 932500, 805785, 812258, 843621, 932500, 805785, 812258, 843621, 932500, 3327556, 3267299, 3226281, 3405545, 320630, 295695, 284068, 546471, 805785, 812258, 843621, 6455930, 6759940, 6713862, 7095053 7098483. Electrical Connections The LED light engines are available with or without Lamina’s EZ-Connect Board. EZ-Connect adapter boards have AMP connectors for solderless connections to Lamina’s wiring harness. As with many electrical devices, RMA type solder flux should be used to prepare the solder pads before application of solder. Ensure proper strain relief of wires attached to the light engine to prevent damage to the light engines solder pads. For more information refer to Lamina’s Connection application note AN-05 which can be found on the website at www.laminalighting.com. Functional test: Parts may be tested using a constant current source set at 25% of specified drive current specified per specification, drawing or datasheet for no more than two seconds without heat sink. Voltage compliance of power source should not exceed forward voltage plus 5 volts. 1. Optical and electrical specifications are given for the specified drive @ 25ºC junction temperature. 2. When using constant current LED drivers with high compliance voltage (Advance, LEDworks, etc. or a custom driver) the output of the supply must be connected to the part before power is applied to the input of the supply. Assembly Recommendations Lamina’s Light Engines are designed for attachment to a heat sink with conductive epoxy or thermal grease in the joint. For attachment using screws, a 2-56 UNC round head or metric equivalent M2 X 0.4 cheese head screw, 18-8 SS is recommended. When mounting the light engine, position the three screws in the center of each of the three slots. Tighten the three screws evenly, first to about 0.89 inch pounds (10 Newton-centimeter), and then tighten each to a maximum torque of 4 inch pounds (45 Newton-centimeter). Flatness requirement of the surface that the light engine is mounted to is 0.001 inch/inch (1mm/meter). Packaging - Receiving Parts and Packaging Trays Your parts will arrive in either custom fitted trays or bulk packaging when appropriate. This packaging was designed or specified to provide the necessary protection during shipment and to take up the least amount of space in your storage area. Notes 1. These products use silicone materials for superior optical performance. Do not expose the part to fluids that may react with silicone compounds. See Dow Chemical Form 45-0113D-01, Silicone Fluid Resistance Guide. 2. Ray trace models are available upon request. 3. Lamina® may make process or materials changes affecting the performance or other characteristics of our products. The products supplied after such changes will continue to meet published specifications, but may not be identical to product supplied as samples or under prior orders. 4. All specifications are based on mounting the LED array to a heat sink using the specified hardware and thermal grease (e.g. Wakefield P/N 120). The heat sink must meet the specified flatness requirement. Mounting using screws and thermal tape may damage the device. 120 Hancock Lane | Westampton, NJ 08060 | info@laminalighting.com | +1.609.265.1401 | 1.800.808.5822 ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 18 RoHS and Warranty Lamina Light Engines Comply with RoHS Restrictions Lamina Light Engines are compliant with all of the criteria proposed by the European RoHS Directive 2002/95/ EC for hazardous material content in electronic and electrical equipment as listed in Annex 1A and 1B of the WEEE Directive. In addition to containing no mercury, Lamina’s LED Light Engines have the following environmental advantages over traditional light sources: • • • • High energy efficiency Long lifetime Fully dimmable Very low IR and UV radiation For attachment of electrical connections Lamina recommends the use of lead-free solder. Warranty Statement Lamina Lighting, Incorporated (Seller) extends warranty on goods produced by the Seller for one (1) year from original date of shipment, that the goods sold hereunder are new and free from substantive defects in workmanship and materials. This warranty extends only to the Buyer and not to indirect purchasers or users. Seller’s liability under the foregoing warranty is limited to replacement of goods or repair of defects or refund of the purchase price at the Seller’s sole option. The above warranty does not apply to defects resulting from the improper or inadequate maintenance, unauthorized modification, improper use or operation outside of Seller’s specifications for the product, abuse, neglect or accident. THE ABOVE WARRANTY IS EXCLUSIVE AND NO OTHER WARRANTY, WHETHER WRITTEN OR ORAL, IS EXPRESSED OR IMPLIED. LAMINA LIGHTING INCORPORATED SPECIFICALLY DISCLAIMS THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. - LAMINA LIGHTING INCORPORATED - June 21, 2006. ©2008 Lamina Lighting Incorporated. Lamina is a registered trademark and the Lamina logo, Atlas, Titan, TitanTurbo, SōL, TruColor, and E-ZConnect are trademarks of Lamina Lighting Incorporated. All other trademarks mentioned are the property of their respective owners. 120 Hancock Lane | Westampton, NJ 08060 | info@laminalighting.com | +1.609.265.1401 | 1.800.808.5822 ©2008 Lamina Lighting Incorporated Light Engine Accessories FM-0169 Rev 05.21.08 Light Engine Accessories 19
OP-5LN1-0451
物料型号: - Atlas™ NT-4000 - Titan™ NT-5000 - TitanTurbo™ NT-5000
器件简介: Lamina® 提供了一系列LED照明辅助配件,这些配件与他们的LED引擎产品配合使用,旨在帮助用户快速验证设计,甚至在适当的情况下推向市场。应用工程师随时准备帮助用户为项目选择合适的部件。
引脚分配: 文档中没有明确提到具体的引脚分配,但提到了使用AMP连接器进行无焊接连接,以及提及了EZ-Connect Board和相应的接线端子。
参数特性: - 热阻抗(Thermal Resistance) - 环境温度上升(Temperature Rise Over Ambient) - 光学性能,包括光束分布和效率 - 电气连接推荐使用无铅焊料
功能详解: - 提供了不同厚度的散热器以适应不同的散热需求。 - 散热器设计用于与Lamina的AtlasTM NT-4000和TitanTM NT-5000系列LED引擎配合使用。 - 光学配件与Fraen Corporation合作开发,提供不同光束分布的透镜。
应用信息: - 散热器的选择应考虑多种因素,包括功耗、环境条件、热路径、期望寿命和光输出。 - LED的光输出受其工作温度影响,增加散热器尺寸通常有助于降低LED工作温度,从而提高光输出。
封装信息: - 提供了详细的机械规格和兼容性信息,包括散热器的尺寸、孔图和光学配件的安装孔模式。
其他信息: - 符合RoHS指令的有害物质限制。 - 提供了一年的有限保修期。
OP-5LN1-0451 价格&库存
很抱歉,暂时无法提供与“OP-5LN1-0451”相匹配的价格&库存,您可以联系我们找货
