10773
10773
    CARCLO
10773 数据手册
B A C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 CUSTOMER DRAWING GENERAL VIEW J E.C.N. 1 18-Aug-10 2 23-03-11 03/11/1294 3 17-Nov-11 11/11/1314 DESCRIPTION FIRST ISSUE ADD RECESS & DIM 1 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm X 6.0 2 I 2 4.95 5.15 SCALE 1:1 4.95 1.25 3 12.5 3 4.95 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4 SECTION X-X 4 GENERAL TOLERANCES (UNLESS STATED) 4.95 5.00 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 X 12.5 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 5 TITLE 10mm IP66 OPTIC WIDE FROSTED DRAWN E 0.2 2.00 2.05 SEE DETAIL 6 CHK'D E DATE MH APP'D DETAIL SCALE 8:1 DATE BB DATE PW SCALE SIZE A B C D E F G H 6 29-Nov-11 10773 CARCLO DRG. No. A3 MATERIAL - UV STABILISED CLEAR POLYCARBONATE 29-Nov-11 CARCLO PART No. 5:1 7 18-Aug-10 60597 I SHEET 2 OF 3 J 7 A B C D E F G H I ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 J E.C.N. DESCRIPTION 1 18-Aug-10 FIRST ISSUE 2 23-Mar-11 03/11/1294 ADD RECESS & DIM 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 1 2 2 2.6 LOCATION HOLE IN PCB 3 LED LENS POSITION 4.95 3 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 GENERAL TOLERANCES (UNLESS STATED) 12.50 4 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER CARCLO 5 5 TITLE 4.95 10mm IP66 OPTIC WIDE FROSTED 2.1 LOCATION HOLE IN PCB X3 12.5 DRAWN CHK'D 6 DATE BB DATE MH APP'D DATE PW SCALE SIZE B C D E F G H 6 29-Nov-11 10773 CARCLO DRG. No. A3 A 29-Nov-11 CARCLO PART No. 5:1 7 18-Aug-10 60597 I SHEET 3 OF 3 J 7
10773 价格&库存
很抱歉,暂时无法提供与“10773”相匹配的价格&库存,您可以联系我们找货
