PRODUCT
DATASHEET
C15800_MOLLY-S
MOLLY-S
~25° spot beam
TECHNICAL SPECIFICATIONS:
Dimensions
Height
ROHS compliant
Ø 69.8 mm
24.8 mm
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
MOLLY-S
Single lens
PMMA
clear
Finish
ORDERING INFORMATION:
Component
C15800_MOLLY-S
» Box size: 480 x 280 x 300 mm
Qty in box
198
MOQ
MPQ
36
18
Box weight (kg)
9.7
Last update: 23/02/2022
Subject to change without prior notice
Published: 03/05/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/10
PRODUCT
DATASHEET
C15800_MOLLY-S
See also our general installation guide: www.ledil.com/installation_guide
2/10
PRODUCT
DATASHEET
C15800_MOLLY-S
PHOTOMETRIC DATA (MEASURED):
LED
V11 HD Gen 8
FWHM / FWTM
21.0° / 36.0°
Efficiency
91 %
Peak intensity
5.4 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
Bender Wirth: 633d 3Hook
LED
Vero SE 13
FWHM / FWTM
23.0° / 40.0°
Efficiency
90 %
Peak intensity
4.2 cd/lm
LEDs/each optic
1
Light colour
White
C16402_CLAMP-VEROSE-13-18
LED
Vero SE 18
FWHM / FWTM
31.0° / 54.0°
Efficiency
88 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
CLL03x/CLU03x
FWHM / FWTM
24.0° / 45.0°
Efficiency
88 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
C16791_CLAMP-Z45-A
TE Connectivity: 2325807-3
3/10
PRODUCT
DATASHEET
C15800_MOLLY-S
LED
CLL03x/CLU03x
FWHM / FWTM
23.0° / 42.0°
Efficiency
87 %
Peak intensity
3.9 cd/lm
LEDs/each optic
1
Light colour
White
C13658_CLAMP-VERO13-18
Bender Wirth: 433 Typ L1
LED
CMA1840
FWHM / FWTM
26.0° / 44.0°
Efficiency
91 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
C14123_CLAMP-CXA15-18
LED
CMA2550
FWHM / FWTM
32.0° / 56.0°
Efficiency
89 %
Peak intensity
2.2 cd/lm
LEDs/each optic
1
Light colour
White
C14036_CLAMP_CXA25-30
LED
CMA3090
FWHM / FWTM
37.0° / 64.0°
Efficiency
86 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
White
4/10
PRODUCT
DATASHEET
C15800_MOLLY-S
LED
CMT14xx
FWHM / FWTM
19.0° / 32.0°
Efficiency
90 %
Peak intensity
6.4 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 434 Typ L1
LED
CMT19xx
FWHM / FWTM
26.0° / 44.0°
Efficiency
90 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 477 Typ L1
LED
CMT28xx
FWHM / FWTM
35.0° / 61.0°
Efficiency
85 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
C13584_CLAMP-VERO29
Bender Wirth: 471 Typ L3
LED
CXA/B 15xx
FWHM / FWTM
17.0° / 30.0°
Efficiency
91 %
Peak intensity
7.6 cd/lm
LEDs/each optic
1
Light colour
White
5/10
PRODUCT
DATASHEET
C15800_MOLLY-S
LED
LUXEON CoB 1204HD
FWHM / FWTM
18.0° / 31.0°
Efficiency
89 %
Peak intensity
7.1 cd/lm
LEDs/each optic
1
Light colour
White
TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1
LED
PrevaLED Core G7 L15 H1
FWHM / FWTM
26.0° / 48.0°
Efficiency
89 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
C16685_CLAMP-PRV-A
LED
Fortimo SLM L13 CoB
FWHM / FWTM
24.0° / 42.0°
Efficiency
89 %
Peak intensity
3.9 cd/lm
LEDs/each optic
1
Light colour
White
TE Connectivity: 2213130-2 + OPTIC CLIP Z50 TYPE1 2213194-1
LED
Fortimo SLM L15 + SLM holder
FWHM / FWTM
26.0° / 47.0°
Efficiency
88 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
TE Connectivity: OPTIC CLIP Z50 TYPE1 2213194-1
6/10
PRODUCT
DATASHEET
C15800_MOLLY-S
LED
Fortimo SLM L15 CoB
FWHM / FWTM
27.0° / 47.0°
Efficiency
88 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
XTM - 19mm LES
FWHM / FWTM
28.0° / 52.0°
Efficiency
89 %
Peak intensity
2.6 cd/lm
LEDs/each optic
1
Light colour
White
C16491_XTM-ADAPTER-50-A
7/10
PRODUCT
DATASHEET
C15800_MOLLY-S
PHOTOMETRIC DATA (SIMULATED):
LED
V9 HD Gen7
FWHM / FWTM
16.0° / 26.0°
Efficiency
91 %
Peak intensity
10.8 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 496 Typ L1
LED
VERO13
FWHM / FWTM
21.0° / 39.0°
Efficiency
90 %
Peak intensity
5.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
CLL02x/CLU02x (LES10)
FWHM / FWTM
16.0° / 30.0°
Efficiency
87 %
Peak intensity
8.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
CXA/B 1816 & CXA/B 1820 & CXA 1850
FWHM / FWTM
19.0° / 34.0°
Efficiency
89 %
Peak intensity
6.5 cd/lm
LEDs/each optic
1
Light colour
White
8/10
PRODUCT
DATASHEET
C15800_MOLLY-S
LED
CXA/B 25xx
FWHM / FWTM
25.0° / 47.0°
Efficiency
85 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CoB 1205HD
FWHM / FWTM
19.0° / 33.0°
Efficiency
86 %
Peak intensity
6.8 cd/lm
LEDs/each optic
1
Light colour
White
Bender Wirth: 480 Typ L1
LED
CTM-18 (Tunable White)
FWHM / FWTM
23.0° / 47.0°
Efficiency
78 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
9/10
PRODUCT
DATASHEET
C15800_MOLLY-S
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
Due to use of high power COB's with this product, special attention to proper
thermal design is highly recommended. LEDiL has no liability for direct,
indirect or consecutive damages arising from the LEDiL products being used
outside of the recommended temperature range.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
10/10
很抱歉,暂时无法提供与“C15800_MOLLY-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+86.746161+11.22112
