CMC_313_ATP
CMC_313_ATP
    VCC
    CMC_313_ATP
CMC_313_ATP 数据手册
8 D 7 5 6 4 NOTES: MOUNTING: Mounts in a .281 .002 [ 7.13mm .05] panel hole on .375 [9.5mm] centers. 1. Panel thickness .031 [0.8mm] to .250 [6.35mm]. Panel hole should be deburred, but not chamfered. 2. ASSEMBLY: Insert lens through panel hole, slide RNG 268 retainer on back of lens. PCB mounted LEDs slide into lens when the panel cover is closed or the PCB card is inserted into the case. MATERIAL: Polycarbonate, UL 94-V2 3. 4. U.S. & Foreign Pat. Issued & Pend. 2 3 ECN# 1 REV. REVISIONS DESCRIPTION 001 REVISED PER ECR111009AZ01 DATE INITIALS 4-23-10 SMU D RETAINER (ORDER SEPARATELY) C C .330 8.38mm RNG 268 .300 7.62mm .281 7.14mm B B .260 6.6mm ORDERING CODE : CMC 313 XXX MODEL RTP ATP GTP BTP YTP CTP A LENS COLOR RED TRANSPARENT AMBER TRANSPARENT GREEN TRANSPARENT BLUE TRANSPARENT YELLOW TRANSPARENT CLEAR TRANSPARENT LENS DISPAY PANEL LED UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES: ANGLES 1' FINISH BREAK ALL CORNERS AND SHARP EDGES .030 MAX 6 190 Bosstick Boulevard, Suite101 San Marcos, CA 92069 USA Phone (760) 560-1300 Fax (760) 560-1301 email vccsales@vcclite.com FINISH TITLE: PCB PROPRIETARY AND CONFIDENTIAL 5 4 3 DRAWN: CHECKED: 5MM ROUND PLAIN DIFFUSED LENS DATE APPROVAL THIRD ANGLE PROJECTION THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF VISUAL COMMUNICATIONS COMPANY, INC. ANY REPRODUCTION IN PART OR AS A WHOLE WITHOUT THE WRITTEN PERMISSION OF VISUAL COMMUNICATIONS COMPANY, INC IS PROHIBITED. 7 VISUAL COMMUNICATIONS COMPANY, INC. POLYCARBONATE, UL 94-V2 SEE NOTES RNG 268 RETAINER ASSEMBLY 8 MATERIAL DECIMALS .X .020 .010 .XX .XXX .005 SMU 4-23-10 DZ 4-23-10 SIZE SCALE: 1:1 DO NOT SCALE DRAWING 2 REV DWG. NO. B CMC 313 XXX 001 SHEET 1 OF 1 1 A
CMC_313_ATP 价格&库存
很抱歉,暂时无法提供与“CMC_313_ATP”相匹配的价格&库存,您可以联系我们找货
