8
D
7
5
6
4
2
3
1
REVISIONS
NOTES:
1.
ROHS COMPLIANT
2.
MATERIAL: LENS - POLYCARBONATE, UL 94-V2
3.
MOISTURE SEAL - EPDM
MOUNTING: MOUNTS IN A .171" .002 [ 4.34mm .05] PANEL HOLE ON
4.
.250" [6.35mm] CENTER
5.
PANEL HOLE SHALL BE DEBURRED, BUT NOT CHAMFERED
6.
PANEL THICKNESS: .031" [.8 mm] to .094" [2.39mm]
7.
ASSEMBLY:
A.) INSERT LENS INTO PANEL HOLE
B.) SLIDE RNG 132 RETAINING RING ON BACK OF LENS
C.) INSERT LED INTO LENS
8.
U.S. & FOREIGN PATENT ISSUED
ECN #
REV.
DESCRIPTION
DATE
INITIALS
CHK'D
353
000
INITIAL RELEASE
2/20/12
KH
AZ
D
RETAINING RING
(ORDER SEPARATELY)
C
C
.270in
6.86mm
MOISTURE
SEAL
RNG 132
.154in
3.91mm
.193in
4.91mm
.170in
4.32mm
B
B
ORDERING CODE :
.192in
4.87mm
SMS 172 XXX
MODEL
RTP
ATP
GTP
BTP
YTP
CTP
A
LENS COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
LENS
DISPLAY PANEL
LED
DIMENSION STYLE: INCHES [MM]
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
.X
.XX
.XXX
INCHES
.020
.010
.005
ANGLE 1'
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
RNG 132
RETAINING RING
2/20/12
CHECKED
AZANELLI
3/5/12
12780 DANIELSON CT, SUITE A, POWAY, CA 92064 U.S.A
PHONE: (800) 522-5546 EMAIL: vccsales@vcclite.com
TITLE:
MATERIAL
SEE NOTES
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL FINISH
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC.
ANY REPRODUCTION IN PART OR AS
A WHOLE WITHOUT THE WRITTEN
PERMISSION OF VISUAL
COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
7
DATE
KHOWARD
PCB
ASSEMBLY
8
APPROVAL
DRAWN
6
5
4
3
3MM FRESNEL LENS
W/ MOISTURE SEAL,
ROUND LOW PROFILE
REV
SIZE DWG. NO.
SEE NOTES
B
SCALE: 10:1
DO NOT SCALE DRAWING
2
000
SMS 172 XXX
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“SMS_172_ATP”相匹配的价格&库存,您可以联系我们找货
