CA12474_SIRI-A
CA12474_SIRI-A
    LEDIL(芬兰)
CA12474_SIRI-A 数据手册
PRODUCT DATASHEET CA12474_SIRI-A SIRI-A ~75° + 135° wide area beam. Assembly with installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 13.9 x 13.9 mm 4.6 mm tape, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour SIRI-A Single lens PMMA clear SIRI-TAPE Tape Acrylic foam Finish ORDERING INFORMATION: Component CA12474_SIRI-A » Box size: 450 x 260 x 160 mm Single lens Qty in box MOQ MPQ 5488 392 196 Last update: 29/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 3.3 1/5 PRODUCT DATASHEET CA12474_SIRI-A See also our general installation guide: www.ledil.com/installation_guide Last update: 29/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/5 PRODUCT DATASHEET CA12474_SIRI-A PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 142.0° / 151.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON R FWHM / FWTM 75.0 + 134.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 58.0 + 132.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 66.0 + 134.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/5 PRODUCT DATASHEET CA12474_SIRI-A PHOTOMETRIC DATA (SIMULATED): LED J Series 2835 FWHM / FWTM 135.0° / 146.0° Efficiency 96 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED J Series 3030 FWHM / FWTM 131.0° / 142.0° Efficiency 96 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 143.0 + 144.0° / 152.0° Efficiency 93 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 116.0 + 132.0° / 137.0 + 148.0° Efficiency 97 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 29/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/5 PRODUCT DATASHEET CA12474_SIRI-A GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 29/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/5
CA12474_SIRI-A
PDF文档中包含以下信息:
1. 物料型号:型号编号为AC7803。
2. 器件简介:AC7803是一款高性能的PWM控制器,用于离线式开关电源。
3. 引脚分配:AC7803共有8个引脚,包括VCC、GND、PWM、VFB、VREF、FB、PGND和PG。
4. 参数特性:AC7803的主要参数包括输入电压范围、输出电压范围、开关频率等。
5. 功能详解:AC7803具有多种保护功能,如过压保护、欠压保护、过热保护等。
6. 应用信息:AC7803适用于AC/DC电源适配器、充电器等应用。
7. 封装信息:AC7803采用SOIC-8封装。
CA12474_SIRI-A 价格&库存
很抱歉,暂时无法提供与“CA12474_SIRI-A”相匹配的价格&库存,您可以联系我们找货
