8
D
5
6
7
4
NOTES:
MOUNTING: Mounts in a .562 .002 [ 16.56mm .05] panel hole on .750 [19.05mm]
1.
centers. Panel thickness .031 [.8mm] to .187 [4.75mm]. Panel hole should be deburred, but not
chamfered.
ASSEMBLY: Insert lens through panel hole, slide lock washer onto lens barrel and twist on
2.
retaining ring. PCB mounted LEDs slide into lens when the panel cover is closed or the PCB
card is inserted into the case.
3.
MATERIAL: Lens-Polycarbonate, UL 94-V2
Lock Washer- FH Steel, Nickel plate
Retaining ring - Thermoplastic, U.L. 94 V0 Rated
Seal- EPDM
4.
U.S. & Foreign Pat. Issued & Pend.
ECN#
C
1
REV.
REVISIONS
DESCRIPTION
001
REVISED PER ECR111009AZ01
DATE
INITIALS
4-23-10
SMU
D
.623
15.82mm
SEAL
2
3
LOCK
WASHER
.550
13.97mm
.620
15.75mm
RETAINING
RING
.780
19.81mm
C
.700
17.78mm
B
B
.035±.003
0.89mm±0.08
.435
11.05mm
.480
12.19mm
ORDERING CODE :
.340
8.64mm
.018
0.44mm
HMS 462 XXX
MODEL
LOCK
WASHER
LED
DIMENSION STYLE: INCHES / MM
GENERAL TOLERANCES UNLESS
OTHERWISE SPECIFIED
VCC
A
DISPLAY
PANEL
.X
.XX
.XXX
PAT. PEND.
RTP
ATP
GTP
BTP
YTP
CTP
LENS COLOR
RED TRANSPARENT
AMBER TRANSPARENT
GREEN TRANSPARENT
BLUE TRANSPARENT
YELLOW TRANSPARENT
CLEAR TRANSPARENT
7
MATERIAL
OPTOELECTRONICS
SEE NOTES
MM
.508
.254
.127
BREAK ALL CORNERS AND SHARP
EDGES .030 MAX
190 BOSSTICK BLVD. SUITE 101 SAN MARCOS, CA 92069 U.S.A
PHONE: (760) 560-1300, FAX: (760) 560-1301 EMAIL: vccsales@vcclite.com
FINISH
TITLE:
SEE NOTES
LENS
RETAINING
PCB
RING
6
5
DATE
APPROVAL
THIRD ANGLE PROJECTION
PROPRIETARY AND CONFIDENTIAL
THE INFORMATION CONTAINED IN THIS
DRAWING IS THE SOLE PROPERTY OF
VISUAL COMMUNICATIONS COMPANY, INC. ANY
REPRODUCTION IN PART OR AS A WHOLE
WITHOUT THE WRITTEN PERMISSION OF
VISUAL COMMUNICATIONS COMPANY, INC IS
PROHIBITED.
ASSEMBLY
8
INCHES
.020
.010
.005
ANGLE 1'
4
3
DRAWN:
CHECKED:
SMU 4-23-10
DZ 4-23-10
SIZE
10MM ROUND STANDARD
THREADED FRESNEL LENS
WITH SEAL
SCALE: 4:1
DO NOT SCALE DRAWING
2
REV
DWG. NO.
B HMS 462 XXX
001
SHEET 1 OF 1
1
A
很抱歉,暂时无法提供与“HMS_462_BTP”相匹配的价格&库存,您可以联系我们找货
