CP12943_LARISA-O-CLIP16
    LEDIL(芬兰)
    ASSEMBLY SQUARE 1 POS 9.9 + 9.9M
CP12943_LARISA-O-CLIP16 数据手册
PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 LARISA-O-CLIP16 ~40° x 20° oval beam. Clip fastening for 1.6 mm thick PCB. TECHNICAL SPECIFICATIONS: Dimensions Height 9.9 x 9.9 mm 7.5 mm Fastening ROHS compliant clips yes MATERIAL SPECIFICATIONS: Component Type Material Colour LARISA-O Single lens PMMA clear LARISA-HOLDER-CLIP16 Holder PC black Finish ORDERING INFORMATION: Component CP12943_LARISA-O-CLIP16 » Box size: 300 x 250 x 250 mm Single lens Qty in box MOQ MPQ 10000 300 100 Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 6.6 1/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 See also our general installation guide: www.ledil.com/installation_guide Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 39.0 + 21.0° / 73.0 + 49.0° Efficiency 80 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XD16 FWHM / FWTM 40.0 + 20.0° / 72.0 + 51.0° Efficiency 75 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 39.0 + 25.0° / 76.0 + 51.0° Efficiency 83 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 40.0 + 17.0° / 68.0 + 42.0° Efficiency 82 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (MEASURED): LED XQ-E HI FWHM / FWTM 43.0 + 14.0° / 64.0 + 36.0° Efficiency 74 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON A FWHM / FWTM 39.0 + 26.0° / 78.0 + 55.0° Efficiency 81 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 40.0 + 18.0° / 69.0 + 43.0° Efficiency 79 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 40.0 + 18.0° / 70.0 + 42.0° Efficiency 84 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (MEASURED): LED LUXEON Rebel ES FWHM / FWTM 39.0 + 25.0° / 77.0 + 54.0° Efficiency 82 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel Plus FWHM / FWTM 40.0 + 19.0° / 69.0 + 46.0° Efficiency 83 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z FWHM / FWTM 41.0 + 14.0° / 62.0 + 360.0° Efficiency 81 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 40.0 + 18.0° / 68.0 + 44.0° Efficiency 86 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (MEASURED): LED NCSxx19A FWHM / FWTM 41.0 + 19.0° / 71.0 + 50.0° Efficiency 81 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 40.0 + 24.0° / 77.0 + 57.0° Efficiency 79 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S5 (2 chip) FWHM / FWTM 26.0 + 41.0° / 63.0 + 77.0° Efficiency 79 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 39.0 + 19.0° / 70.0 + 40.0° Efficiency 84 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (MEASURED): LED OSLON SSL 80 FWHM / FWTM 40.0 + 17.0° / 70.0 + 48.0° Efficiency 77 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 PHOTOMETRIC DATA (SIMULATED): LED XP-E FWHM / FWTM 39.0 + 17.0° Efficiency 89 % LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET CP12943_LARISA-O-CLIP16 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 17/11/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
物料型号:CP12943 LARISA-O-CLIP16
器件简介: - LARISA-O-CLIP16是LED光学元件,具有约40° x 20°的椭圆形光束。 - 设计用于1.6毫米厚的PCB板上,通过夹子固定。
引脚分配: - 为以下引脚孔尺寸设计:孔径1.95毫米,孔距8.6毫米。
参数特性: - 尺寸:9.9 x 9.9毫米(高度7.5毫米) - 夹子符合ROHS标准。
功能详解: - 提供了与不同LED型号(如CREE、LUMILEDS、NICHIA、OSRAM)兼容的光度数据,包括半高全宽(FWHM)、半宽全高(FWTM)、效率和峰值强度。
应用信息: - LARISA-O-CLIP16适用于需要特定光束形状和尺寸的应用场合。
封装信息: - 材料规格:LARISA-O为单透镜,材料为PMMA(聚甲基丙烯酸甲酯),颜色为透明;LARISA-HOLDER-CLIP16为支架,材料为PC(聚碳酸酯),颜色为黑色。 - 订购信息:每个盒子包含10000个组件,最小订购量(MOQ)为300,混合最小订购量(MPQ)为100,每个盒子重量为6.6公斤。
其他信息: - LEDiL公司保留随时更改材料等级的权利,以确保产品质量和供应。 - 产品数据表中的数据是参考值,实际数据可能会有所变化。 - LEDiL公司不对提供的数据的准确性或完整性提供任何保证。
CP12943_LARISA-O-CLIP16 价格&库存
很抱歉,暂时无法提供与“CP12943_LARISA-O-CLIP16”相匹配的价格&库存,您可以联系我们找货
