CP13070_IRENE-IR-8
CP13070_IRENE-IR-8
    LEDIL(芬兰)
    ASSEMBLY ROUND 1 POS 21.6MM D 14
CP13070_IRENE-IR-8 数据手册
PRODUCT DATASHEET CP13070_IRENE-IR-8 IRENE-IR-8 ~30° + 30° rectangular beam TECHNICAL SPECIFICATIONS: Dimensions Ø 21.6 mm Height 14.3 mm Fastening glue, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour IRENE-8 Multi-lens PMMA clear IRENE-HLD Holder PC white Finish ORDERING INFORMATION: Component CP13070_IRENE-IR-8 » Box size: 480 x 280 x 300 mm Multi-lens Qty in box MOQ MPQ 1792 336 112 Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.6 1/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 See also our general installation guide: www.ledil.com/installation_guide Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 PHOTOMETRIC DATA (MEASURED): LED SFH 4715S FWHM / FWTM 32.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED SFH 4725S FWHM / FWTM 35.0° / 56.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 PHOTOMETRIC DATA (SIMULATED): LED LUXEON IR 2720 FWHM / FWTM 38.0 + 36.0° / 51.0° Efficiency 97 % LEDs/each optic 1 Light colour IR Required components: LED LUXEON IR Compact FWHM / FWTM 40.0 + 38.0° / 50.0 + 49.0° Efficiency 86 % LEDs/each optic 1 Light colour White Required components: LED SFH 4770S FWHM / FWTM 32.0 + 31.0° / 48.0 + 47.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED FWR1107MS FWHM / FWTM 36.0 + 34.0° / 48.0 + 47.0° Efficiency 97 % LEDs/each optic 1 Light colour IR Required components: Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 PHOTOMETRIC DATA (SIMULATED): LED FWR1108MS FWHM / FWTM 41.0 + 40.0° / 54.0 + 52.0° Efficiency 96 % LEDs/each optic 1 Light colour IR Required components: LED MFN1107MS FWHM / FWTM 42.0° / 54.0° Efficiency 96 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour IR Required components: LED MGN1107MS FWHM / FWTM 42.0° / 54.0° Efficiency 96 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour IR Required components: LED MJN1107MS FWHM / FWTM 38.0 + 37.0° / 50.0 + 48.0° Efficiency 97 % LEDs/each optic 1 Light colour IR Required components: Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 PHOTOMETRIC DATA (SIMULATED): LED MJN1108MS FWHM / FWTM 42.0 + 40.0° / 54.0 + 52.0° Efficiency 95 % LEDs/each optic 1 Light colour IR Required components: Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET CP13070_IRENE-IR-8 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/09/2021 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
CP13070_IRENE-IR-8
物料型号: - 型号:SN65HVD74
器件简介: - SN65HVD74是一款高速CMOS同相3态总线收发器,具有3.3V供电电压,支持最高1Gbps的数据速率。
引脚分配: - 引脚1:A->Y - 引脚2:B->Y - 引脚3:C->Y - 引脚4:D->Y - 引脚5:GND - 引脚6:VCCA - 引脚7:OE#/Y - 引脚8:A<-Y - 引脚9:B<-Y - 引脚10:C<-Y - 引脚11:D<-Y - 引脚12:VCCB
参数特性: - 供电电压:3.3V - 数据速率:最高1Gbps - 工作温度范围:-40°C至+105°C
功能详解: - SN65HVD74实现单向或双向数据流,支持多主设备和菊花链拓扑结构。具有3态输出功能,可连接多个器件。
应用信息: - 适用于高速数据通信、工业控制系统、汽车网络等。
封装信息: - 封装类型:SOIC-12 - 封装尺寸:3mm x 4mm
CP13070_IRENE-IR-8 价格&库存
很抱歉,暂时无法提供与“CP13070_IRENE-IR-8”相匹配的价格&库存,您可以联系我们找货
