CA12079_HEIDI-W2
CA12079_HEIDI-W2
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM RND 11.5MM
CA12079_HEIDI-W2 数据手册
PRODUCT DATASHEET CA12079_HEIDI-W2 HEIDI-W2 ~45° wide beam TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 21.6 mm 12 mm tape, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour HEIDI-W2 Single lens PMMA clear HEIDI-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA12079_HEIDI-W2 » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 3264 204 204 Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 11.1 1/18 PRODUCT DATASHEET CA12079_HEIDI-W2 See also our general installation guide: www.ledil.com/installation_guide Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 46.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-H FWHM / FWTM 45.0° / 76.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM 46.0° / 80.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 44.0° / 72.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED XP-E FWHM / FWTM 44.0° / 70.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 45.0° / 72.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 44.0° / 72.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 46.0° / 74.0° Efficiency 80 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED XP-G3 FWHM / FWTM 42.0° / 73.0° Efficiency 91 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 44.0° / 74.0° Efficiency 79 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 44.0° / 70.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 42.0° / 72.0° Efficiency 87 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED XT-E FWHM / FWTM 42.0° / 71.0° Efficiency 75 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 40.0° / 69.0° Efficiency 71 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 42.0° / 70.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 49.0° / 76.0° Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED LUXEON T FWHM / FWTM 44.0° / 72.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 44.0° / 74.0° Efficiency 78 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SST-10-B130 FWHM / FWTM 43.0° / 72.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED NCSxx19B FWHM / FWTM 45.0° / 74.0° Efficiency 78 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED NVSW219D FWHM / FWTM 45.0° / 72.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM 44.0° / 73.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 42.0° / 75.0° Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 41.0° / 73.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED NVSxx19A FWHM / FWTM 48.0° / 78.0° Efficiency 79 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 44.0 + 43.0° / 73.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 44.0° / 76.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 43.0° / 71.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED OSLON SSL 150 FWHM / FWTM 40.0° / 67.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 47.0° / 76.0° Efficiency 80 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH181A FWHM / FWTM 38.0° / 71.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH181B FWHM / FWTM 40.0° / 72.0° Efficiency 90 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED LH351Z FWHM / FWTM 46.0° / 74.0° Efficiency 82 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 44.0° / 73.0° Efficiency 76 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 44.0° / 73.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 43.0° / 77.0° Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (MEASURED): LED Double Dome (GM2BB) FWHM / FWTM 44.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (SIMULATED): LED XP-G2 HE FWHM / FWTM 45.0° / 70.0° Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 50.0° / 76.0° Efficiency 93 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 HE Plus FWHM / FWTM 48.0° / 68.0° Efficiency 95 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 HV FWHM / FWTM 46.0° / 67.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (SIMULATED): LED LUXEON HL2X FWHM / FWTM 47.0° / 68.0° Efficiency 95 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 44.0° / 62.0° Efficiency 95 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 21.0° / 58.0° Efficiency 88 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z FWHM / FWTM 46.0° / 64.0° Efficiency 95 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (SIMULATED): LED LUXEON Z ES FWHM / FWTM 43.0° / 67.0° Efficiency 94 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 47.0° / 66.0° Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 48.0° / 72.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 46.0° / 70.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (SIMULATED): LED NVSxE21A FWHM / FWTM 46.0° / 72.0° Efficiency 92 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3030 FWHM / FWTM 46.0° / 68.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 Flat FWHM / FWTM 47.0° / 70.0° Efficiency 96 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 48.0° / 68.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/18 PRODUCT DATASHEET CA12079_HEIDI-W2 PHOTOMETRIC DATA (SIMULATED): LED SFH 4170S FWHM / FWTM 41.0° / 64.0° Efficiency 87 % LEDs/each optic 1 Light colour IR Required components: LED SFH 4716AS FWHM / FWTM 41.0° / 64.0° Efficiency 93 % LEDs/each optic 1 Light colour IR Required components: LED Z5M4 FWHM / FWTM 46.0° / 67.0° Efficiency 96 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/18 PRODUCT DATASHEET CA12079_HEIDI-W2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 20/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/18
CA12079_HEIDI-W2 价格&库存
很抱歉,暂时无法提供与“CA12079_HEIDI-W2”相匹配的价格&库存,您可以联系我们找货
CA12079_HEIDI-W2
    • 204+14.63733204+1.73160
    • 408+14.35584408+1.69830
    CA12079_HEIDI-W2
    • 204+10.03971204+1.18770
    • 408+9.94588408+1.17660
    • 612+9.89918612+1.17108
    • 816+9.89896816+1.17105
    • 1020+9.758221020+1.15440
    CA12079_HEIDI-W2
    • 10+12.1039410+1.43190
    • 40+11.9162940+1.40970
    • 125+11.72863125+1.38750
    • 400+11.63480400+1.37640
    • 1250+11.259481250+1.33200
