PRODUCT
DATASHEET
CA12530_HEIDI-D
HEIDI-D
~10° diffused spot beam optimized for LUXEON
Rebel ES
TECHNICAL SPECIFICATIONS:
Dimensions
Ø 21.6 mm
Height
11.7 mm
Fastening
tape, pin
ROHS compliant
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
HEIDI-D
Single lens
PMMA
clear
HEIDI-TAPE
Tape
Acrylic foam
black
Finish
ORDERING INFORMATION:
Component
CA12530_HEIDI-D
» Box size: 480 x 280 x 300 mm
Single lens
Qty in box
MOQ
MPQ
3264
204
204
Last update: 07/06/2018
Subject to change without prior notice
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
Box weight (kg)
10.3
1/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
See also our general installation guide: www.ledil.com/installation_guide
2/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
PHOTOMETRIC DATA (MEASURED):
LED
XHP35 HD
FWHM / FWTM
20.0° / 46.0°
Efficiency
83 %
Peak intensity
4.2 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XHP35 HI
FWHM / FWTM
17.0° / 38.0°
Efficiency
94 %
Peak intensity
5.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2
FWHM / FWTM
15.0° / 36.0°
Efficiency
94 %
Peak intensity
6.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G3
FWHM / FWTM
17.0° / 40.0°
Efficiency
94 %
Peak intensity
5.1 cd/lm
LEDs/each optic
1
Light colour
White
3/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
XP-L HD
FWHM / FWTM
18.0° / 41.0°
Efficiency
85 %
Peak intensity
4.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
14.0° / 32.0°
Efficiency
94 %
Peak intensity
7.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON A
FWHM / FWTM
12.0° / 26.0°
Efficiency
86 %
Peak intensity
10 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rebel
FWHM / FWTM
14.0° / 34.0°
Efficiency
86 %
Peak intensity
7.5 cd/lm
LEDs/each optic
1
Light colour
White
4/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
LUXEON Rebel ES
FWHM / FWTM
15.0° / 36.0°
Efficiency
91 %
Peak intensity
6.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
SST-10-B130
FWHM / FWTM
14.0° / 32.0°
Efficiency
93 %
Peak intensity
7.9 cd/lm
LEDs/each optic
1
Light colour
Blue
LED
NVSW219D
FWHM / FWTM
16.0° / 39.0°
Efficiency
94 %
Peak intensity
5.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSW319B
FWHM / FWTM
18.0° / 41.0°
Efficiency
93 %
Peak intensity
5.2 cd/lm
LEDs/each optic
1
Light colour
White
5/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
NVSW3x9A
FWHM / FWTM
18.0° / 41.0°
Efficiency
90 %
Peak intensity
4.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSW519A
FWHM / FWTM
20.0° / 45.0°
Efficiency
94 %
Peak intensity
4.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
NWSx229A
FWHM / FWTM
20.0° / 45.0°
Efficiency
84 %
Peak intensity
4.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
13.0° / 30.0°
Efficiency
87 %
Peak intensity
9.1 cd/lm
LEDs/each optic
1
Light colour
White
6/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
Z5M3
FWHM / FWTM
17.0° / 40.0°
Efficiency
94 %
Peak intensity
5.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y22P
FWHM / FWTM
17.0° / 39.0°
Efficiency
92 %
Peak intensity
5 cd/lm
LEDs/each optic
1
Light colour
White
7/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
PHOTOMETRIC DATA (SIMULATED):
LED
XP-G2 HE
FWHM / FWTM
14.0° / 28.0°
Efficiency
95 %
Peak intensity
10.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON R
FWHM / FWTM
12.0° / 26.0°
Efficiency
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 20 Line (120 deg)
FWHM / FWTM
9.0° / 18.0°
Efficiency
96 %
Peak intensity
26.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 20 Line (150 deg)
FWHM / FWTM
8.7° / 18.0°
Efficiency
93 %
Peak intensity
25.6 cd/lm
LEDs/each optic
1
Light colour
White
8/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
FWHM / FWTM
8.0° / 18.0°
Efficiency
92 %
Peak intensity
24.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 35 Line
FWHM / FWTM
8.5° / 18.0°
Efficiency
94 %
Peak intensity
27.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Z ES
FWHM / FWTM
10.0° / 21.0°
Efficiency
94 %
Peak intensity
20.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxE17A
FWHM / FWTM
10.0° / 20.0°
Efficiency
92 %
Peak intensity
18.2 cd/lm
LEDs/each optic
1
Light colour
White
9/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
LED
NV4WB35AM
FWHM / FWTM
16.0° / 32.0°
Efficiency
96 %
Peak intensity
7.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxE21A
FWHM / FWTM
10.0° / 22.0°
Efficiency
94 %
Peak intensity
17.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 3737 Flat
FWHM / FWTM
11.0° / 23.0°
Efficiency
97 %
Peak intensity
15.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351C
FWHM / FWTM
14.0° / 26.0°
Efficiency
96 %
Peak intensity
11.8 cd/lm
LEDs/each optic
1
Light colour
White
10/11
PRODUCT
DATASHEET
CA12530_HEIDI-D
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
11/11
很抱歉,暂时无法提供与“CA12530_HEIDI-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+21.36399
- 20+20.50485
- 112+20.09350
