CA14000_HEIDI-M-NP
CA14000_HEIDI-M-NP
    LEDIL(芬兰)
CA14000_HEIDI-M-NP 数据手册
PRODUCT DATASHEET CA14000_HEIDI-M-NP HEIDI-M-NP ~25° medium beam. Version without location pins. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 21.6 mm 11.6 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour HEIDI-M-NP Single lens PMMA clear HEIDI-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA14000_HEIDI-M-NP » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 3264 204 204 Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 10.8 1/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP See also our general installation guide: www.ledil.com/installation_guide Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (MEASURED): LED LH351B FWHM / FWTM 29.0° / 51.0° Efficiency 88 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 30.0° / 50.0° Efficiency 89 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (SIMULATED): LED ML-E FWHM / FWTM 28.0° / 49.0° Efficiency 92 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-D FWHM / FWTM 28.0° / 46.0° Efficiency 89 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 28.0° / 45.0° Efficiency 93 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 29.0° / 46.0° Efficiency 93 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (SIMULATED): LED XP-G FWHM / FWTM 28.0° / 48.0° Efficiency 92 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 29.0° / 49.0° Efficiency 92 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 30.0° / 51.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 28.0° / 51.0° Efficiency 94 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (SIMULATED): LED XT-E FWHM / FWTM 27.0° / 47.0° Efficiency 93 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 20 Line (120 deg) FWHM / FWTM 29.0° / 47.0° Efficiency 96 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 28.0° / 45.0° Efficiency 91 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 27.0° / 45.0° Efficiency 94 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (SIMULATED): LED 107 FWHM / FWTM 28.0° / 47.0° Efficiency 90 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757A FWHM / FWTM 27.0° / 47.0° Efficiency 93 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NSSW157T FWHM / FWTM 28.0° / 43.0° Efficiency 93 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 29.0° / 46.0° Efficiency 92 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP PHOTOMETRIC DATA (SIMULATED): LED OSLON SSL 150 FWHM / FWTM 29.0° / 44.0° Efficiency 93 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 29.0° / 46.0° Efficiency 92 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5P FWHM / FWTM 28.0° / 46.0° Efficiency 92 % Peak intensity 3.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET CA14000_HEIDI-M-NP GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 23/05/2018 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
CA14000_HEIDI-M-NP 价格&库存
很抱歉,暂时无法提供与“CA14000_HEIDI-M-NP”相匹配的价格&库存,您可以联系我们找货
