C11601_SATU-S
C11601_SATU-S
    LEDIL(芬兰)
    LENS 3POS 21.8MM ROUND OD 8.9MM
C11601_SATU-S 数据手册
LEDIL F’FORM OPTICS SATU-RE LENS FOR LUXEON REBEL LEDs - - Specially designed for Luxeon Rebel series of LEDs. Lens material optical grade PMMA with high UV and temperature resistance (105°C/220°F) High optical efficiency, >90% No lens holder. Fastening to heat sink with droplets of glue. Please check fastening details from this link: (http://www.ledil.com/datasheets/DataSheet_GLUES.pdf) Very compact dimensions Diameter 21.8 mm LENS TYPES NAME ORDERING CODE FWHM Angle SATU spot SATU medium SATU wide C11601_Satu-S-RE C11602_Satu-M-RE C11544_Satu-W-RE ±9° ±12° ±16° © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-10-14 LEDIL F’FORM OPTICS MEASUREMENT DATA & PHOTOGRAPHS © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-10-14 LEDIL F’FORM OPTICS © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-10-14 LEDIL F’FORM OPTICS © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-10-14 LEDIL F’FORM OPTICS DRAWINGS © Ledil Oy – PRELIMINARY - Subject to change without prior notice Ledil Oy Tehdaskatu 13 FIN-24100 SALO, Finland www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 2010-10-14 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Ledil: C11601_SATU-S C11601_Satu-S-RE
C11601_SATU-S
1. 物料型号:文档中提到了三种型号的透镜,分别是C11601 Satu-S-RE、C11602 Satu-M-RE和C11544 Satu-W-RE。
2. 器件简介:这些透镜是为Luxeon Rebel系列LED特别设计的,采用高光学效率的光学级PMMA材料,具有高UV和温度抵抗力(105°C/220°F)。
3. 引脚分配:文档中没有提及引脚分配信息。
4. 参数特性:透镜具有不同的FWHM角度,分别为±9°、±12°和±16°,对应不同的光束宽度。
5. 功能详解:文档提供了三种透镜的相对强度图,显示了它们的光分布特性。
6. 应用信息:透镜设计用于与Luxeon Rebel系列LED配合使用,但没有提供具体的应用场景。
7. 封装信息:透镜尺寸紧凑,直径为21.8mm,采用PMMA材料,且不需要透镜支架,可以通过胶水快速固定到散热器上。
8. 其他信息:文档还包含了透镜的图纸,显示了不同视图下的尺寸和形状。
C11601_SATU-S 价格&库存
很抱歉,暂时无法提供与“C11601_SATU-S”相匹配的价格&库存,您可以联系我们找货
