CA11931_LR2-M
CA11931_LR2-M
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM RND 14.3MM
CA11931_LR2-M 数据手册
PRODUCT DATASHEET CA11931_LR2-M LR2-M ~25° medium beam optimized for LUXEON Rebel ES. 14.8 mm high assembly with installation tape. TECHNICAL SPECIFICATIONS: Dimensions Ø 21.6 mm Height 14.8 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LXP2-M Single lens PMMA clear LR2-ES-LH1-HLD Holder PC white HEIDI-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11931_LR2-M » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 1680 336 112 Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 9.0 1/8 PRODUCT DATASHEET CA11931_LR2-M See also our general installation guide: www.ledil.com/installation_guide Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET CA11931_LR2-M PHOTOMETRIC DATA (MEASURED): LED XP-L HD FWHM / FWTM 24.0° / 46.0° Efficiency 90 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 22.0° Efficiency 92 % LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 25.0° / 44.0° Efficiency 90 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 24.0° / 42.0° Efficiency 90 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET CA11931_LR2-M PHOTOMETRIC DATA (MEASURED): LED LUXEON Z ES FWHM / FWTM 23.0° / 40.0° Efficiency 90 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 22.0° / 42.0° Efficiency 94 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 25.0° / 42.0° Efficiency 89 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET CA11931_LR2-M PHOTOMETRIC DATA (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 28.0° / 56.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 26.0° / 42.0° Efficiency 94 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Square LES FWHM / FWTM 29.0° / 57.0° Efficiency 96 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 25.0° / 43.0° Efficiency 92 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET CA11931_LR2-M PHOTOMETRIC DATA (SIMULATED): LED LUXEON IR Domed 60 FWHM / FWTM 24.0° / 44.0° Efficiency 93 % LEDs/each optic 1 Light colour IR Required components: LED LUXEON V2 FWHM / FWTM 26.0° / 45.0° Efficiency 94 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 28.0° / 50.0° Efficiency 95 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 30.0° / 61.0° Efficiency 93 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET CA11931_LR2-M PHOTOMETRIC DATA (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 26.0° / 43.0° Efficiency 95 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET CA11931_LR2-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
CA11931_LR2-M 价格&库存
很抱歉,暂时无法提供与“CA11931_LR2-M”相匹配的价格&库存,您可以联系我们找货
CA11931_LR2-M
    • 112+10.35660112+1.29870
    • 336+10.17956336+1.27650
    • 560+10.13177560+1.27051
    • 1680+10.002531680+1.25430
    • 2800+9.914012800+1.24320
    CA11931_LR2-M
    • 112+9.20587112+1.15440
    • 336+9.02883336+1.13220
    • 448+8.94031448+1.12110
    • 1120+8.719021120+1.09335
    • 1680+8.541981680+1.07115
    CA11931_LR2-M
    • 112+13.01214112+1.63170
    • 224+12.83510224+1.60950
    • 336+12.77484336+1.60195
    • 448+12.74658448+1.59840
    • 560+12.56955560+1.57620
