CA11847_TINA2-RS
CA11847_TINA2-RS
    LEDIL(芬兰)
    LENS ASSY 1POS 16.1MM RND 10.1MM
CA11847_TINA2-RS 数据手册
PRODUCT DATASHEET CA11847_TINA2-RS TINA2-RS ~14° spot beam optimized for Osram Golden Dragon+. Assembly with holder and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 16.1 mm 10.1 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour TINA2-O-PLUS-RS Single lens PMMA clear TINA2-O-PLUS-HLD-WHT Holder PC white TINA-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11847_TINA2-RS » Box size: 451 x 241 x 298 mm Single lens Qty in box MOQ MPQ 4140 230 230 Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 0.0 1/9 PRODUCT DATASHEET CA11847_TINA2-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (MEASURED): LED Golden Dragon+ FWHM / FWTM 10.0° / 20.0° Efficiency 93 % Peak intensity 18 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (SIMULATED): LED XP-G2 HE FWHM / FWTM 17.0° / 34.0° Efficiency 88 % Peak intensity 6.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 16.0° / 34.0° Efficiency 85 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 12.0° / 30.0° Efficiency 89 % Peak intensity 9.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 12.0° / 30.0° Efficiency 82 % Peak intensity 8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (SIMULATED): LED LUXEON 3030 HE Plus FWHM / FWTM 14.0° / 34.0° Efficiency 87 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Square LES FWHM / FWTM 22.0° / 52.0° Efficiency 85 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 8.0° / 20.0° Efficiency 88 % Peak intensity 22.5 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON IR Domed 150 FWHM / FWTM 10.0° / 27.0° Efficiency 81 % LEDs/each optic 1 Light colour IR Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (SIMULATED): LED NV4WB35AM FWHM / FWTM 20.0° / 44.0° Efficiency 86 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 16.0° / 32.0° Efficiency 89 % Peak intensity 7.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 20.0° / 38.0° Efficiency 85 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 16.0° / 33.0° Efficiency 84 % Peak intensity 6.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (SIMULATED): LED Duris S8 FWHM / FWTM 25.0° / 59.0° Efficiency 85 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED KW CULPM1.TG FWHM / FWTM 10.0° / 24.0° Efficiency 89 % Peak intensity 15.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED PLPVEC2 850A FWHM / FWTM 10.0° / 23.0° Efficiency 93 % LEDs/each optic 1 Light colour IR Required components: LED SFH 4232A FWHM / FWTM 8.0° / 19.0° Efficiency 94 % LEDs/each optic 1 Light colour IR Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET CA11847_TINA2-RS PHOTOMETRIC DATA (SIMULATED): LED SFH 4715AS FWHM / FWTM 17.0° / 35.0° Efficiency 88 % LEDs/each optic 1 Light colour IR Required components: LED SFH 4725S FWHM / FWTM 14.0° / 32.0° Efficiency 88 % LEDs/each optic 1 Light colour IR Required components: LED SFH 4727AS FWHM / FWTM 23.0° / 42.0° Efficiency 86 % LEDs/each optic 1 Light colour IR Required components: LED LH351C FWHM / FWTM 16.0° / 34.0° Efficiency 91 % Peak intensity 7.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET CA11847_TINA2-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
CA11847_TINA2-RS 价格&库存
很抱歉,暂时无法提供与“CA11847_TINA2-RS”相匹配的价格&库存,您可以联系我们找货
CA11847_TINA2-RS
  • 230+12.86807230+1.60950
  • 460+12.60183460+1.57620
