PRODUCT
DATASHEET
CA12375_TINA2-D
TINA2-D
~16° diffused spot beam. Assembly with holder,
installation tape and location pins.
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
ROHS compliant
Ø 16.0 mm
9.5 mm
tape, pin
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
TINA2-XP-D
Single lens
PMMA
clear
TINA2-HLD-BLK
Holder
PC
black
TINA-TAPE3
Tape
Acrylic foam
black
Finish
ORDERING INFORMATION:
Component
CA12375_TINA2-D
» Box size: 451 x 241 x 298 mm
Single lens
Qty in box
MOQ
MPQ
4140
230
230
Box weight (kg)
8.1
Last update: 20/04/2022
Subject to change without prior notice
Published: 16/11/2018
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/10
PRODUCT
DATASHEET
CA12375_TINA2-D
See also our general installation guide: www.ledil.com/installation_guide
2/10
PRODUCT
DATASHEET
CA12375_TINA2-D
PHOTOMETRIC DATA (MEASURED):
LED
XB-H
FWHM / FWTM
16.0° / 34.0°
Efficiency
86 %
Peak intensity
7.7 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XD16
FWHM / FWTM
14.0° / 29.0°
Efficiency
82 %
Peak intensity
9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Z ES
FWHM / FWTM
12.0° / 27.0°
Efficiency
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
18.0° / 36.0°
Efficiency
87 %
Peak intensity
6.1 cd/lm
LEDs/each optic
1
Light colour
White
3/10
PRODUCT
DATASHEET
CA12375_TINA2-D
LED
OSLON Square EC
FWHM / FWTM
16.0° / 33.0°
Efficiency
82 %
Peak intensity
7.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square EC
FWHM / FWTM
16.0° / 34.0°
Efficiency
87 %
Peak intensity
6.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square PC
FWHM / FWTM
13.0° / 32.0°
Efficiency
87 %
Peak intensity
6.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
14.0° / 28.0°
Efficiency
89 %
Peak intensity
9.3 cd/lm
LEDs/each optic
1
Light colour
White
4/10
PRODUCT
DATASHEET
CA12375_TINA2-D
LED
OSLON SSL 80
FWHM / FWTM
12.0° / 35.0°
Efficiency
87 %
Peak intensity
7.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
SFH 4170S
FWHM / FWTM
8.0° / 20.0°
Efficiency
LEDs/each optic
1
Light colour
IR
LED
SFH 4180S
FWHM / FWTM
8.0° / 20.0°
Efficiency
LEDs/each optic
1
Light colour
IR
LED
Z5M3
FWHM / FWTM
18.0° / 38.0°
Efficiency
86 %
Peak intensity
5.6 cd/lm
LEDs/each optic
1
Light colour
White
5/10
PRODUCT
DATASHEET
CA12375_TINA2-D
PHOTOMETRIC DATA (SIMULATED):
LED
XB-D
FWHM / FWTM
18.0° / 34.0°
Efficiency
88 %
Peak intensity
7.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HI
FWHM / FWTM
11.0° / 23.0°
Efficiency
91 %
Peak intensity
18.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 2835 Line
FWHM / FWTM
15.0° / 31.0°
Efficiency
96 %
Peak intensity
9.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
Duris E 2835
FWHM / FWTM
17.0° / 34.0°
Efficiency
92 %
Peak intensity
7.6 cd/lm
LEDs/each optic
1
Light colour
White
6/10
PRODUCT
DATASHEET
CA12375_TINA2-D
LED
Duris S5 (2 chip)
FWHM / FWTM
17.0° / 33.0°
Efficiency
92 %
Peak intensity
8 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 3030
FWHM / FWTM
12.0° / 26.0°
Efficiency
91 %
Peak intensity
13.2 cd/lm
LEDs/each optic
1
Light colour
Blue
LED
OSLON Signal
FWHM / FWTM
12.0° / 26.0°
Efficiency
92 %
Peak intensity
14.4 cd/lm
LEDs/each optic
1
Light colour
Blue
LED
OSLON Square Flat
FWHM / FWTM
12.0° / 24.0°
Efficiency
91 %
Peak intensity
14.5 cd/lm
LEDs/each optic
1
Light colour
White
7/10
PRODUCT
DATASHEET
CA12375_TINA2-D
LED
OSLON SSL 80
FWHM / FWTM
12.0° / 31.0°
Efficiency
90 %
Peak intensity
9.9 cd/lm
LEDs/each optic
1
Light colour
Far Red
LED
OSTAR Projection Compact (Kx.CSLNM1.xx)
FWHM / FWTM
12.0° / 24.0°
Efficiency
92 %
Peak intensity
16.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
SFH 4715AS
FWHM / FWTM
14.0° / 26.0°
Efficiency
90 %
LEDs/each optic
1
Light colour
IR
LED
SFH 4770S
FWHM / FWTM
12.0° / 22.0°
Efficiency
92 %
LEDs/each optic
1
Light colour
IR
8/10
PRODUCT
DATASHEET
CA12375_TINA2-D
LED
LH181B
FWHM / FWTM
16.0° / 30.5°
Efficiency
92 %
Peak intensity
9.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y15
FWHM / FWTM
13.0° / 25.0°
Efficiency
90 %
Peak intensity
13.8 cd/lm
LEDs/each optic
1
Light colour
White
9/10
PRODUCT
DATASHEET
CA12375_TINA2-D
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
10/10
很抱歉,暂时无法提供与“CA12375_TINA2-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 4+11.08553
- 60+10.84393
- 116+10.61170
- 国内价格
- 230+13.58590
- 460+13.24640
- 920+13.04333
- 国内价格 香港价格
- 230+8.47096230+1.06005
- 460+8.33790460+1.04340
- 690+8.24920690+1.03230
- 920+8.20485920+1.02675
- 1150+8.027451150+1.00455
- 国内价格 香港价格
- 230+12.86166230+1.60950
- 460+12.59555460+1.57620
