C13529_VERONICA-O
C13529_VERONICA-O
    LEDIL(芬兰)
    LENS ROUND 1 POS 26MM D 12.2MMH
C13529_VERONICA-O 数据手册
PRODUCT DATASHEET C13529_VERONICA-O VERONICA-O ~55° + 10° oval beam TECHNICAL SPECIFICATIONS: Dimensions Ø 26.0 mm Height 12.2 mm Fastening glue, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour VERONICA-O Single lens PMMA clear Finish ORDERING INFORMATION: Component C13529_VERONICA-O » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 2240 336 112 Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 11.1 1/13 PRODUCT DATASHEET C13529_VERONICA-O See also our general installation guide: www.ledil.com/installation_guide Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED MK-R FWHM / FWTM 48.0 + 28.0° / 85.0 + 58.0° Efficiency 80 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM 52.0 + 19.0° / 84.0 + 44.0° Efficiency 80 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 53.0 + 16.0° / 82.0 + 38.0° Efficiency 82 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 54.0 + 18.0° / 81.0 + 40.0° Efficiency 83 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED XM-L2 FWHM / FWTM 54.0 + 18.0° / 81.0 + 41.0° Efficiency 82 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 54.0 + 11.0° / 76.0 + 26.0° Efficiency 83 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 54.0 + 11.0° / 76.0 + 27.0° Efficiency 84 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 55.0 + 13.0° / 79.0 + 30.0° Efficiency 83 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 55.0 + 13.0° / 78.0 + 30.0° Efficiency 84 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 54.0 + 15.0° / 79.0 + 33.0° Efficiency 81 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON A FWHM / FWTM 54.0 + 15.0° / 79.0 + 33.0° Efficiency 82 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 49.0 + 28.0° / 84.0 + 57.0° Efficiency 79 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED LUXEON R FWHM / FWTM 54.0 + 16.0° / 79.0 + 34.0° Efficiency 81 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 54.0 + 14.0° / 78.0 + 31.0° Efficiency 82 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 54.0 + 17.0° / 80.0 + 34.0° Efficiency 81 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM 52.0 + 16.0° / 78.0 + 36.0° Efficiency 90 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED NCSxx19B FWHM / FWTM 52.0 + 15.0° / 80.0 + 32.0° Efficiency 80 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 53.0 + 15.0° / 79.0 + 36.0° Efficiency 91 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 53.0 + 16.0° / 80.0 + 35.0° Efficiency 80 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 53.0 + 18.0° / 80.0 + 36.0° Efficiency 79 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED NVSxx19B/NVSxx19C FWHM / FWTM 54.0 + 17.0° / 79.0 + 35.0° Efficiency 79 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 54.0 + 14.0° / 79.0 + 32.0° Efficiency 81 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 54.0 + 15.0° / 79.0 + 32.0° Efficiency 81 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 54.0 + 11.0° / 76.0 + 24.0° Efficiency 83 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED LH351B FWHM / FWTM 54.0 + 14.0° / 79.0 + 33.0° Efficiency 84 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 54.0 + 13.0° / 78.0 + 31.0° Efficiency 83 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 54.0 + 13.0° / 77.0 + 28.0° Efficiency 83 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 54.0 + 15.0° / 79.0 + 33.0° Efficiency 83 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (MEASURED): LED Z8Y22P FWHM / FWTM 52.0 + 17.0° / 79.0 + 37.0° Efficiency 77 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y50P FWHM / FWTM 48.0 + 29.0° / 84.0 + 58.0° Efficiency 73 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (SIMULATED): LED XP-G2 HE FWHM / FWTM 54.0 + 14.0° / 80.0 + 32.0° Efficiency 90 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 52.0 + 18.0° / 82.0 + 38.0° Efficiency 91 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 54.0 + 16.0° / 82.0 + 37.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 7070 FWHM / FWTM 48.0 + 25.0° / 85.0 + 50.0° Efficiency 85 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/13 PRODUCT DATASHEET C13529_VERONICA-O PHOTOMETRIC DATA (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 57.0 + 11.0° / 80.0 + 26.0° Efficiency 92 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT 3030 FWHM / FWTM 56.0 + 12.0° / 78.0 + 28.0° Efficiency 90 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED MJT 5050 FWHM / FWTM 50.0 + 30.0° / 87.0 + 68.0° Efficiency 78 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M4 FWHM / FWTM 54.0 + 14.0° / 80.0 + 32.0° Efficiency 90 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/13 PRODUCT DATASHEET C13529_VERONICA-O GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/10/2020 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/13
C13529_VERONICA-O 价格&库存
很抱歉,暂时无法提供与“C13529_VERONICA-O”相匹配的价格&库存,您可以联系我们找货
C13529_VERONICA-O
  • 112+11.06443112+1.38750
  • 224+10.97591224+1.37640
  • 336+10.88740336+1.36530
  • 448+10.83604448+1.35886
  • 560+10.71037560+1.34310
C13529_VERONICA-O
  • 112+9.29412112+1.16550
  • 336+9.20560336+1.15440
  • 560+9.11709560+1.14330
  • 2240+9.028572240+1.13220
  • 3360+8.851543360+1.11000
