CA13629_G2-LAURA-D-P
    LEDIL(芬兰)
CA13629_G2-LAURA-D-P 数据手册
PRODUCT DATASHEET CA13629_G2-LAURA-D-P G2-LAURA-D-P ~13° diffused spot beam. Assembly with thinner white holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions 21.6 x 21.6 mm Height 13.1 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LAURA-D Single lens PMMA clear LAURA-LT-PIN-XP-HLD-WHT Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA13629_G2-LAURA-D-P » Box size: 451 x 254 x 152 mm Single lens Qty in box MOQ MPQ 1440 360 180 Box weight (kg) 5.9 Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P See also our general installation guide: www.ledil.com/installation_guide Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (MEASURED): LED XB-H FWHM / FWTM 19.0° / 41.0° Efficiency 83 % Peak intensity 4.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 13.0° / 31.0° Efficiency 93 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 16.0° / 37.0° Efficiency 83 % Peak intensity 6.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 19.0° / 40.0° Efficiency 83 % Peak intensity 5.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (MEASURED): LED XP-L HD FWHM / FWTM 21.0° / 45.0° Efficiency 81 % Peak intensity 3.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 22.0° / 48.0° Efficiency 84 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 19.0° / 41.0° Efficiency 82 % Peak intensity 4.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM 18.0° / 38.0° Efficiency 87 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (MEASURED): LED LUXEON TX FWHM / FWTM 18.0° / 40.0° Efficiency 86 % Peak intensity 5.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 19.0° / 41.0° Efficiency 87 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM / FWTM 17.0° / 38.0° Efficiency 83 % Peak intensity 5.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219D FWHM / FWTM 18.0° / 40.0° Efficiency 94 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (MEASURED): LED NVSxx19A FWHM / FWTM 20.0° / 43.0° Efficiency 81 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 19.0° / 42.0° Efficiency 83 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 19.0° / 40.0° Efficiency 82 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM 21.0° / 46.0° Efficiency 93 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (MEASURED): LED Z5M1/Z5M2 FWHM / FWTM 18.0° / 39.0° Efficiency 83 % Peak intensity 4.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 19.0° / 42.0° Efficiency 93 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (SIMULATED): LED XHP35 HI FWHM / FWTM 14.0° / 26.0° Efficiency 94 % Peak intensity 12.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 14.0° / 28.0° Efficiency 93 % Peak intensity 11.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 10.8° / 21.2° Efficiency 94 % Peak intensity 20.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NS9x383 FWHM / FWTM 16.0° / 30.0° Efficiency 94 % Peak intensity 8.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (SIMULATED): LED KW CULPM1.TG FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 21.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 10.0° / 20.0° Efficiency 95 % Peak intensity 24.2 cd/lm LEDs/each optic 1 Light colour Red Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 12.0° / 25.0° Efficiency 96 % Peak intensity 14.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square Flat FWHM / FWTM 9.0° / 19.0° Efficiency 94 % Peak intensity 26.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P PHOTOMETRIC DATA (SIMULATED): LED OSLON SSL 80 FWHM / FWTM 10.0° / 22.0° Efficiency 95 % Peak intensity 18.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 13.0° / 25.0° Efficiency 97 % Peak intensity 13.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/11 PRODUCT DATASHEET CA13629_G2-LAURA-D-P GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 02/11/2021 Subject to change without prior notice Published: 25/10/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/11
CA13629_G2-LAURA-D-P 价格&库存
很抱歉,暂时无法提供与“CA13629_G2-LAURA-D-P”相匹配的价格&库存,您可以联系我们找货
