CA13627_G2-LAURA-M-P 数据手册
PRODUCT
DATASHEET
G2-LAURA-M-P
~30° medium beam. Assembly with thinner
white holder, installation tape and location pins.
TECHNICAL SPECIFICATIONS:
Dimensions
21.6 x 21.6 mm
Height
13.1 mm
Fastening
tape, pin
ROHS compliant
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
LAURA-M
Single lens
PMMA
clear
LAURA-LT-PIN-XP-HLD-WHT
Holder
PC
white
ROSE-TAPE
Tape
Acrylic foam
black
Finish
ORDERING INFORMATION:
Component
» Box size:
Qty in box
Single lens
MOQ
MPQ
360
180
Box weight (kg)
6.2
Last update: 20/03/2019
Subject to change without prior notice
Published: 11/07/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/12
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XB-H
FWHM / FWTM
33.0° / 59.0°
Efficiency
85 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XP-E
FWHM / FWTM
30.0° / 53.0°
Efficiency
92 %
Peak intensity
2.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E2
FWHM / FWTM
31.0° / 56.0°
Efficiency
85 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
33.0° / 59.0°
Efficiency
83 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
3/12
PRODUCT
DATASHEET
LED
XP-G2
FWHM / FWTM
33.0° / 58.0°
Efficiency
85 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
31.0° / 58.0°
Efficiency
85 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 3030 2D (Round LES)
FWHM / FWTM
25.0° / 51.0°
Efficiency
85 %
Peak intensity
3.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
30.0° / 57.0°
Efficiency
86 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
4/12
PRODUCT
DATASHEET
LED
NCSxx19A
FWHM / FWTM
29.0° / 55.0°
Efficiency
86 %
Peak intensity
2.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSW219D
FWHM / FWTM
38.0° / 63.0°
Efficiency
92 %
Peak intensity
1.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19A
FWHM / FWTM
30.0° / 58.0°
Efficiency
85 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
28.0° / 56.0°
Efficiency
84 %
Peak intensity
2.8 cd/lm
LEDs/each optic
1
Light colour
White
5/12
PRODUCT
DATASHEET
LED
OSLON Square EC
FWHM / FWTM
32.0° / 58.0°
Efficiency
85 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square PC
FWHM / FWTM
31.0° / 57.0°
Efficiency
84 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351D
FWHM / FWTM
40.0° / 67.0°
Efficiency
92 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M1/Z5M2
FWHM / FWTM
30.0° / 56.0°
Efficiency
84 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
6/12
PRODUCT
DATASHEET
LED
Z5M3
FWHM / FWTM
29.0° / 57.0°
Efficiency
90 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
7/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
XHP35 HI
FWHM / FWTM
28.0° / 61.0°
Efficiency
93 %
Peak intensity
2.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-L2
FWHM / FWTM
38.0° / 63.0°
Efficiency
93 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HD
FWHM / FWTM
32.3° / 55.7°
Efficiency
94 %
Peak intensity
2.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HI
FWHM / FWTM
27.0° / 49.0°
Efficiency
94 %
Peak intensity
3.7 cd/lm
LEDs/each optic
1
Light colour
White
8/12
PRODUCT
DATASHEET
LED
KW CULPM1.TG
FWHM / FWTM
30.0° / 51.0°
Efficiency
96 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Black
FWHM / FWTM
22.0° / 40.0°
Efficiency
94 %
Peak intensity
5.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Black Flat
FWHM / FWTM
21.0° / 42.0°
Efficiency
94 %
Peak intensity
5.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Signal
FWHM / FWTM
30.0° / 51.0°
Efficiency
96 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
Red
9/12
PRODUCT
DATASHEET
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
34.0° / 58.0°
Efficiency
95 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square Flat
FWHM / FWTM
24.0° / 45.0°
Efficiency
94 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
30.0° / 53.0°
Efficiency
94 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 80
FWHM / FWTM
29.0° / 53.0°
Efficiency
95 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
10/12
PRODUCT
DATASHEET
LED
SFH 4770S
FWHM / FWTM
27.0° / 56.0°
Efficiency
88 %
LEDs/each optic
1
Light colour
White
LED
Z8Y22P
FWHM / FWTM
29.0° / 51.0°
Efficiency
94 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
11/12
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
12/12
CA13627_G2-LAURA-M-P 价格&库存
很抱歉,暂时无法提供与“CA13627_G2-LAURA-M-P”相匹配的价格&库存,您可以联系我们找货
