CA13628_G2-LAURA-RS-P 数据手册
PRODUCT
DATASHEET
G2-LAURA-RS-P
~8° spot beam. Assembly with thinner white
holder, installation tape and location pins.
TECHNICAL SPECIFICATIONS:
Dimensions
21.6 x 21.6 mm
Height
13.1 mm
Fastening
tape, pin
ROHS compliant
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
LAURA-RS
Single lens
PMMA
clear
LAURA-LT-PIN-XP-HLD-WHT
Holder
PC
white
ROSE-TAPE
Tape
Acrylic foam
black
Finish
ORDERING INFORMATION:
Component
» Box size:
Qty in box
Single lens
MOQ
MPQ
360
180
Box weight (kg)
5.9
Last update: 18/10/2022
Subject to change without prior notice
Published: 11/07/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/12
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XB-H
FWHM / FWTM
11.0° / 20.0°
Efficiency
91 %
Peak intensity
20.5 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XP-E
FWHM / FWTM
8.0° / 16.0°
Efficiency
93 %
Peak intensity
33.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E2
FWHM / FWTM
8.0° / 15.0°
Efficiency
91 %
Peak intensity
41.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-L HD
FWHM / FWTM
16.0° / 27.0°
Efficiency
90 %
Peak intensity
10.3 cd/lm
LEDs/each optic
1
Light colour
White
3/12
PRODUCT
DATASHEET
LED
XQ-E HI
FWHM / FWTM
5.0° / 11.0°
Efficiency
94 %
Peak intensity
65.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 3030 2D (Round LES)
FWHM / FWTM
9.0° / 20.0°
Efficiency
92 %
Peak intensity
22.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
11.0° / 21.0°
Efficiency
90 %
Peak intensity
20 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxx19A
FWHM / FWTM
10.0° / 20.0°
Efficiency
90 %
Peak intensity
25.3 cd/lm
LEDs/each optic
1
Light colour
White
4/12
PRODUCT
DATASHEET
LED
NVSW219D
FWHM / FWTM
12.0° / 22.0°
Efficiency
94 %
Peak intensity
15.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19A
FWHM / FWTM
12.0° / 23.0°
Efficiency
90 %
Peak intensity
17.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
12.0° / 24.0°
Efficiency
90 %
Peak intensity
16.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
PLPVEC2 850A
FWHM / FWTM
6.0° / 14.0°
Efficiency
LEDs/each optic
1
Light colour
IR
5/12
PRODUCT
DATASHEET
LED
LH351D
FWHM / FWTM
16.0° / 29.0°
Efficiency
94 %
Peak intensity
9 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M1/Z5M2
FWHM / FWTM
11.0° / 19.0°
Efficiency
91 %
Peak intensity
20 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M3
FWHM / FWTM
12.0° / 24.0°
Efficiency
94 %
Peak intensity
14.4 cd/lm
LEDs/each optic
1
Light colour
White
6/12
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
XD16
FWHM / FWTM
9.0° / 18.0°
Efficiency
93 %
Peak intensity
27 cd/lm
LEDs/each optic
1
Light colour
White
LED
XHP35 HD
FWHM / FWTM
14.0° / 35.0°
Efficiency
94 %
Peak intensity
7.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XHP35 HI
FWHM / FWTM
12.0° / 23.0°
Efficiency
94 %
Peak intensity
16.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G3
FWHM / FWTM
12.0° / 24.0°
Efficiency
92 %
Peak intensity
14.7 cd/lm
LEDs/each optic
1
Light colour
White
7/12
PRODUCT
DATASHEET
LED
XP-P
FWHM / FWTM
6.0° / 14.0°
Efficiency
94 %
Peak intensity
53.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XQ-E HD
FWHM / FWTM
6.9° / 14.5°
Efficiency
94 %
Peak intensity
44.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CZ
FWHM / FWTM
6.0° / 13.0°
Efficiency
95 %
Peak intensity
54.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON HL1Z
FWHM / FWTM
8.0° / 16.0°
Efficiency
95 %
Peak intensity
33.8 cd/lm
LEDs/each optic
1
Light colour
White
8/12
PRODUCT
DATASHEET
LED
LUXEON Z ES
FWHM / FWTM
8.0° / 16.0°
Efficiency
95 %
Peak intensity
37.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxE17A
FWHM / FWTM
8.0° / 18.0°
Efficiency
95 %
Peak intensity
30.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxE21A
FWHM / FWTM
10.0° / 21.0°
Efficiency
94 %
Peak intensity
21.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Black
FWHM / FWTM
9.5° / 20.0°
Efficiency
97 %
Peak intensity
23 cd/lm
LEDs/each optic
1
Light colour
White
9/12
PRODUCT
DATASHEET
LED
OSLON Black Flat
FWHM / FWTM
6.8° / 14.0°
Efficiency
94 %
Peak intensity
48.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
8.0° / 16.0°
Efficiency
95 %
Peak intensity
37.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 80
FWHM / FWTM
8.0° / 16.0°
Efficiency
95 %
Peak intensity
34.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
SFH 4715S
FWHM / FWTM
9.0° / 18.0°
Efficiency
95 %
Peak intensity
29.2 cd/lm
LEDs/each optic
1
Light colour
IR
10/12
PRODUCT
DATASHEET
LED
SFH 4770S
FWHM / FWTM
10.0° / 23.0°
Efficiency
94 %
LEDs/each optic
1
Light colour
White
LED
LH351B
FWHM / FWTM
12.0° / 24.0°
Efficiency
95 %
Peak intensity
15.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351Z
FWHM / FWTM
10.0° / 18.0°
Efficiency
93 %
Peak intensity
25 cd/lm
LEDs/each optic
1
Light colour
White
11/12
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
12/12
CA13628_G2-LAURA-RS-P 价格&库存
很抱歉,暂时无法提供与“CA13628_G2-LAURA-RS-P”相匹配的价格&库存,您可以联系我们找货
