CA13630_G2-LAURA-SS-P
    LEDIL(芬兰)
CA13630_G2-LAURA-SS-P 数据手册
PRODUCT DATASHEET CA13630_G2-LAURA-SS-P G2-LAURA-SS-P ~11° smooth spot beam. Assembly with thinner white holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions 21.6 x 21.6 mm Height 13.1 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LAURA-SS Single lens PMMA LAURA-LT-PIN-XP-HLD-WHT Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA13630_G2-LAURA-SS-P » Box size: Qty in box Single lens MOQ MPQ 360 180 Box weight (kg) 6.0 Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P See also our general installation guide: www.ledil.com/installation_guide Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 13.0° / 24.0° Efficiency 88 % Peak intensity 13.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-H FWHM / FWTM 13.0° / 25.0° Efficiency 90 % Peak intensity 13.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 11.0° / 19.0° Efficiency 93 % Peak intensity 16.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 12.0° / 21.0° Efficiency 90 % Peak intensity 17.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 13.0° / 24.0° Efficiency 90 % Peak intensity 14 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 16.0° / 30.0° Efficiency 89 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 17.0° / 34.0° Efficiency 88 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 13.0° / 25.0° Efficiency 90 % Peak intensity 12.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (MEASURED): LED LUXEON 3030 2D (Round LES) FWHM / FWTM 13.0° / 26.0° Efficiency 91 % Peak intensity 11.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 14.0° / 26.0° Efficiency 90 % Peak intensity 12.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 14.0° / 26.0° Efficiency 91 % Peak intensity 12.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219D FWHM / FWTM 13.0° / 25.0° Efficiency 94 % Peak intensity 12.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (MEASURED): LED NVSxx19A FWHM / FWTM 15.0° / 28.0° Efficiency 88 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 14.0° / 27.0° Efficiency 89 % Peak intensity 11.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 13.0° / 25.0° Efficiency 90 % Peak intensity 13.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM 17.0° / 32.0° Efficiency 94 % Peak intensity 7.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (MEASURED): LED Z5M1/Z5M2 FWHM / FWTM 12.0° / 24.0° Efficiency 90 % Peak intensity 13.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 14.0° / 28.0° Efficiency 94 % Peak intensity 9.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (SIMULATED): LED XHP35 HI FWHM / FWTM 14.0° / 26.0° Efficiency 94 % Peak intensity 12.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 12.0° / 23.0° Efficiency 95 % Peak intensity 17.2 cd/lm LEDs/each optic 1 Light colour Amber Required components: LED XP-G3 FWHM / FWTM 15.0° / 29.0° Efficiency 93 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 12.0° / 21.6° Efficiency 94 % Peak intensity 18.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (SIMULATED): LED LUXEON HL2X FWHM / FWTM 14.0° / 26.0° Efficiency 94 % Peak intensity 12.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X-P FWHM / FWTM 15.0° / 28.0° Efficiency 94 % Peak intensity 10.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Black FWHM / FWTM 13.0° / 25.0° Efficiency 96 % Peak intensity 13.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Black Flat FWHM / FWTM 11.0° / 20.0° Efficiency 94 % Peak intensity 21.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (SIMULATED): LED OSLON Signal FWHM / FWTM 12.0° / 20.0° Efficiency 96 % Peak intensity 20.5 cd/lm LEDs/each optic 1 Light colour Red Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 18.0° / 35.0 + 33.0° Efficiency 96 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square Flat FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 17.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4770S FWHM / FWTM 13.0° / 28.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P PHOTOMETRIC DATA (SIMULATED): LED Z8Y22P FWHM / FWTM 13.0° / 26.0° Efficiency 97 % Peak intensity 11.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/12 PRODUCT DATASHEET CA13630_G2-LAURA-SS-P GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 17/05/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/12
物料型号:CA13630_G2-LAURA-SS-P
器件简介:G2-LAURA-SS-P是一款具有约11°平滑聚光束角的组件,配备更薄的白色支架、安装胶带和定位销。
引脚分配:文档中没有提供具体的引脚分配信息。
参数特性: - 尺寸:21.6 x 21.6 mm,高度13.1 mm - 固定方式:胶带和销钉 - 符合ROHS标准
功能详解:文档提供了不同LED型号的光度数据,包括CREE、LUMILEDS、NICHIA、OSRAM和SAMSUNG等品牌的LED,涉及不同的半功率角(FWHM)、全宽半高(FWTM)、效率、峰值强度等参数。
应用信息:文档中没有提供具体的应用信息,但根据光度数据,该产品可能适用于需要聚光照明的场合。
封装信息:文档提供了详细的机械绘图,包括等距视图、顶视图、底视图和前视图,以及尺寸信息。
CA13630_G2-LAURA-SS-P 价格&库存
很抱歉,暂时无法提供与“CA13630_G2-LAURA-SS-P”相匹配的价格&库存,您可以联系我们找货
