CA13634_G2-LAURA-W-P
    LEDIL(芬兰)
CA13634_G2-LAURA-W-P 数据手册
PRODUCT DATASHEET CA13634_G2-LAURA-W-P G2-LAURA-W-P ~45° wide beam. Assembly with thinner white holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions 21.6 x 21.6 mm Height 13.1 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LAURA-W Single lens PMMA clear LAURA-LT-PIN-XP-HLD-WHT Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA13634_G2-LAURA-W-P » Box size: 450 x 260 x 160 mm Single lens Qty in box MOQ MPQ 1440 360 180 Box weight (kg) 6.1 Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P See also our general installation guide: www.ledil.com/installation_guide Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 40.0° / 69.0° Efficiency 84 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-H FWHM / FWTM 47.0° / 71.0° Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 45.0° / 69.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 45.0° / 69.0° Efficiency 87 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (MEASURED): LED XP-G FWHM / FWTM 46.0° / 65.0° Efficiency 91 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 47.0° / 71.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 49.0° / 76.0° Efficiency 85 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 46.0° / 74.0° Efficiency 83 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (MEASURED): LED XT-E FWHM / FWTM 43.0° / 69.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 3030 2D (Round LES) FWHM / FWTM 37.0° / 62.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 42.0° / 67.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 41.0° / 66.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (MEASURED): LED NVSW219F FWHM / FWTM 48.0° / 76.0° Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 41.0° / 67.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 41.0° / 68.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 46.0° / 71.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (MEASURED): LED LH351D FWHM / FWTM 52.0° / 81.0° Efficiency 92 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 43.0° / 72.0° Efficiency 92 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (SIMULATED): LED XHP35 HI FWHM / FWTM 45.0° / 65.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 50.0° / 68.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 46.0° / 60.0° Efficiency 95 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Black FWHM / FWTM 41.0° / 55.0° Efficiency 95 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P PHOTOMETRIC DATA (SIMULATED): LED OSLON Black Flat FWHM / FWTM 34.0° / 54.0° Efficiency 94 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square Flat FWHM / FWTM 41.0° / 59.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4770S FWHM / FWTM 27.0° / 50.0° Efficiency 93 % LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 40.0° / 62.0° Efficiency 98 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET CA13634_G2-LAURA-W-P GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/07/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
CA13634_G2-LAURA-W-P 价格&库存
很抱歉,暂时无法提供与“CA13634_G2-LAURA-W-P”相匹配的价格&库存,您可以联系我们找货
